having trouble picking up just boosted
so i jus got thru boosting my ls vtec and i switched out the fuel filter injectors and still have my stock map sensor.... when it started it was picking up sort of with no problem then when i got in it, it was struggling to pick up on 2k 3k rpms and after awhile it just started to idle low n struggle way more? ???? & im leaving a trail of black smoke lol
my radiator hoses get fat like they are pressured up aswell?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 »</TD></TR><TR><TD CLASS="quote">not yet but my boi said i should be able to boost...</TD></TR></TABLE>
well then your "boi" is an idiot.....
^ lol
https://honda-tech.com/zerothread?id=878397
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">
Do I need to drive it 500 miles before I tune it? Absolutely not. How about 50 miles? No. Perhaps the best thing to do is to drive it all the way to your trailer and tow it to a competent tuner. In second position on the “things NOT to do list” is trying to break in an un-tuned engine by driving it. Too lean an air/fuel will begin to heat and distort parts, too rich will wash the oil off the cylinders causing premature wear. What is in first place on the “things NOT to do list”? Boost on an un-tuned motor. Within 2 to 3 seconds the pistons and cylinders can be ruined.
I cannot stress enough that if you boost on a un tuned motor you WILL melt your pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 »</TD></TR><TR><TD CLASS="quote">thnkz n im wondering why my hoses get so swollen up i have to take the radi cap off pressured up like bad</TD></TR></TABLE>
hmm..maybe you have really thin hoses? or you could have massive amount of air in your coolant. But on the other hand, if you had that much air in your coolant you would not be able to drive down to the end of your street without overheating. You said you boosted on your motor already (unfortunately) so I'm guessing you arnt overheating..
yeah i chek my temp as well n im not overheating i cant even move without my car struggling..... this is my first time boosting too apreciate it bro
np. If you absolutely have drive your car before you get it tuned, take out your wastegate spring as a fail safe. Removing it will prevent you from hitting boost granted your not WOT. Even without a spring, it is still possible to hit 1-2psi under full throttle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">
well then your "boi" is an idiot.....</TD></TR></TABLE>
Yup, and remember, when you blow your engine, a quick hone with the pistons in will fix everything.
yeah so i could drive it without the wastegate cuz i have to drive a long way to get it tuned n no truck plus gas high like a muthafuka lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 »</TD></TR><TR><TD CLASS="quote">yeah so i could drive it without the wastegate cuz i have to drive a long way to get it tuned n no truck plus gas high like a muthafuka lol</TD></TR></TABLE>
...why don't you pull your BOV off instead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday »</TD></TR><TR><TD CLASS="quote">
I hope your kidding..
</TD></TR></TABLE>I hope your kidding..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94delslo »</TD></TR><TR><TD CLASS="quote">
I hope your kidding..</TD></TR></TABLE>
No, not kidding.
*Waits for the omgbbq unfiltered air comment even though there's 1505211211020 people running straight screens on their turbo's*
No, not kidding.
hmm. I know if you drive with your IC piping off you can over spin the turbo. Wouldn't removing the BOV be the same concept? or is that something completely different?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 »</TD></TR><TR><TD CLASS="quote">cool so ride without the bov? n all i got is my ls v chipped im like 2 hours away from my tuner which really sucks</TD></TR></TABLE> same here... what part of tex u from bro?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94delslo »</TD></TR><TR><TD CLASS="quote">hmm. I know if you drive with your IC piping off you can over spin the turbo. Wouldn't removing the BOV be the same concept? or is that something completely different? </TD></TR></TABLE>
No, you're right, you can. He can't go around punching the gas and whatnot, but it's a smaller leak compared to pulling the IC piping off and the turbo will still have some resistance so that he can drive normally and not have to worry about ruining the turbo.
B16Civic93
Mar 27, 2005 04:48 PM
turbo*s2k
Mar 31, 2004 03:27 PM
