Turbo with No boost? why!?
Old Jul 26, 2008 | 06:03 PM
Maple50175's Avatar
Default Turbo with No boost? why!?
ok so I installed a turbo kit. overall install went ok. I finished up today and well, of course i have a slight oil leak from the stupid oil line in the back of motor, and coolant but that's easy to fix and will do tomorrow.
My T25 garret turbo spins when I start my car and is working. Car idles and starts perfect. Using emanage.
ok so the vacuum lines go like this:
Vacuum line from the motor (next to throttle body to):
Boost Gauge//Blow Off Valve//Emanagevacc
Are these 3 things that only use the vacuum lines? and is it hooked up this way?
I have NO boost at all. and I don't get why. All my IC fittings are tight as hell I cant figure any leaks.....
As far as my wastegate, its an internal wastegaste. Now theres a vac line that goes from the wastegate actuator to the Turbo. Thats correct right?
SO what else could be a reason why I have No boost!?
Old Jul 26, 2008 | 07:28 PM
VTECth1s's Avatar
Default Re: Turbo with No boost? why!? (Maple50175)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maple50175 &raquo;</TD></TR><TR><TD CLASS="quote">ok so I installed a turbo kit. overall install went ok. I finished up today and well, of course i have a slight oil leak from the stupid oil line in the back of motor, and coolant but that's easy to fix and will do tomorrow.
SO what else could be a reason why I have No boost!?</TD></TR></TABLE>
Why dont you run on a separate vacuum hose from the gauge to a vac source from the IM. Also turbo needs load, you can't boost when the car is not in motion.
No matter how high you rev it, you won't see boost unless the car is under load. Meaning your driving the car.
Old Jul 26, 2008 | 08:02 PM
teddy_dc2's Avatar
wastegate might be left open? shaft play? pix?
Old Jul 26, 2008 | 08:58 PM
delhondasol6's Avatar
check your charge pipes
Old Jul 26, 2008 | 09:05 PM
awdgsx96's Avatar
Default Re: Turbo with No boost? why!? (VTECth1s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s &raquo;</TD></TR><TR><TD CLASS="quote">
It's a T25 lol, they'll make some boost without load
Old Jul 26, 2008 | 10:23 PM
ke98248's Avatar
Default Re: Turbo with No boost? why!? (awdgsx96)
Probably spoolin' on idle... lol
Old Jul 27, 2008 | 07:49 AM
Maple50175's Avatar
Default Re: Turbo with No boost? why!? (ke98248)
i checked everything and nothing. Im taking off the exhaust right now since my old exhaut is hooked up and SUPER low to the groun and is draggin then im gonna go drive it and see what happens
Old Jul 27, 2008 | 07:50 AM
Maple50175's Avatar
Default Re: (teddy_dc2)
No shaft play at all the turbo is a garret and in excellent condition.
Emanage the light on the left side blinks twice intermetialttly, and the light on the right side stays on i think
Old Jul 27, 2008 | 03:58 PM
Maple50175's Avatar
Default Re: (Maple50175)
hey so yeah I got ir started everything works fine
I do have a coolant line from turbo that has a hole in it, which is really pissing me off, I think I got it like that. But ill order a new one, get the midpipe made when I get home from work early and figure out the little things i have to go over.
How do you calibrate a boost gauge?
Modified by Maple50175 at 5:34 PM 7/27/2008
Old Jul 27, 2008 | 04:07 PM
teddy_dc2's Avatar
my buddies run turbo d16's with dsm t25 turbos on stock motors and i recall them spooling around 2krpm and like reaching 7-8 psi by 3-3.5k rpm. it seems almost effortless to boost those things. i don't understand why you would have to take it that hard on the highway just to get it to boost... unless boost leak... ever think about chipping your ecu? xenocron is where my buddies go though. good price. i wouldn't trust emanage, only as temp.
B18C_EJ8
Feb 23, 2008 03:10 PM
elnoyl
Nov 4, 2006 11:10 PM
mugenhatch92
Apr 25, 2005 07:32 PM
yusoslo
Apr 19, 2004 09:54 AM
FastNFurious
May 7, 2003 01:00 PM
