having trouble picking up just boosted
Old Jul 26, 2008 | 11:25 AM
HondaKid936's Avatar
Default having trouble picking up just boosted
so i jus got thru boosting my ls vtec and i switched out the fuel filter injectors and still have my stock map sensor.... when it started it was picking up sort of with no problem then when i got in it, it was struggling to pick up on 2k 3k rpms and after awhile it just started to idle low n struggle way more? ???? & im leaving a trail of black smoke lol
my radiator hoses get fat like they are pressured up aswell?
Old Jul 26, 2008 | 11:31 AM
94delslo's Avatar
Default Re: having trouble picking up just boosted (HondaKid936)
Is your engine tuned?
Old Jul 26, 2008 | 11:35 AM
Default Re: having trouble picking up just boosted (94delslo)
not yet but my boi said i should be able to boost...
Old Jul 26, 2008 | 11:36 AM
kyden's Avatar
bigger injectors + stock ecu = pig rich. don't be stupid, get it tuned.
Old Jul 26, 2008 | 11:44 AM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 &raquo;</TD></TR><TR><TD CLASS="quote">not yet but my boi said i should be able to boost...</TD></TR></TABLE>
well then your "boi" is an idiot.....
Old Jul 26, 2008 | 11:56 AM
Default Re: having trouble picking up just boosted (96 GSR-T)
thnkz n im wondering why my hoses get so swollen up i have to take the radi cap off pressured up like bad
Old Jul 26, 2008 | 11:58 AM
94delslo's Avatar
^ lol
https://honda-tech.com/zerothread?id=878397
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">
Do I need to drive it 500 miles before I tune it? Absolutely not. How about 50 miles? No. Perhaps the best thing to do is to drive it all the way to your trailer and tow it to a competent tuner. In second position on the “things NOT to do list” is trying to break in an un-tuned engine by driving it. Too lean an air/fuel will begin to heat and distort parts, too rich will wash the oil off the cylinders causing premature wear. What is in first place on the “things NOT to do list”? Boost on an un-tuned motor. Within 2 to 3 seconds the pistons and cylinders can be ruined.
I cannot stress enough that if you boost on a un tuned motor you WILL melt your pistons.
Old Jul 26, 2008 | 12:11 PM
94delslo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 &raquo;</TD></TR><TR><TD CLASS="quote">thnkz n im wondering why my hoses get so swollen up i have to take the radi cap off pressured up like bad</TD></TR></TABLE>
hmm..maybe you have really thin hoses? or you could have massive amount of air in your coolant. But on the other hand, if you had that much air in your coolant you would not be able to drive down to the end of your street without overheating. You said you boosted on your motor already (unfortunately) so I'm guessing you arnt overheating..
Old Jul 26, 2008 | 12:59 PM
yeah i chek my temp as well n im not overheating i cant even move without my car struggling..... this is my first time boosting too apreciate it bro
Old Jul 26, 2008 | 01:34 PM
94delslo's Avatar
np. If you absolutely have drive your car before you get it tuned, take out your wastegate spring as a fail safe. Removing it will prevent you from hitting boost granted your not WOT. Even without a spring, it is still possible to hit 1-2psi under full throttle.
Old Jul 26, 2008 | 01:44 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">
well then your "boi" is an idiot.....</TD></TR></TABLE>
Yup, and remember, when you blow your engine, a quick hone with the pistons in will fix everything.
Old Jul 26, 2008 | 02:29 PM
Default Re: having trouble picking up just boosted (SovXietday)
yeah so i could drive it without the wastegate cuz i have to drive a long way to get it tuned n no truck plus gas high like a muthafuka lol
Old Jul 26, 2008 | 02:36 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 &raquo;</TD></TR><TR><TD CLASS="quote">yeah so i could drive it without the wastegate cuz i have to drive a long way to get it tuned n no truck plus gas high like a muthafuka lol</TD></TR></TABLE>
...why don't you pull your BOV off instead.
Old Jul 26, 2008 | 02:47 PM
VTECth1s's Avatar
What about running a basemap? just so you can drive it to a "competent tuner". And not driving in boost.
Old Jul 26, 2008 | 02:49 PM
94delslo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">
...why don't you pull your BOV off instead. </TD></TR></TABLE>
I hope your kidding..
Old Jul 26, 2008 | 02:54 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94delslo &raquo;</TD></TR><TR><TD CLASS="quote">
I hope your kidding..</TD></TR></TABLE>
No, not kidding.
*Waits for the omgbbq unfiltered air comment even though there's 1505211211020 people running straight screens on their turbo's*
Old Jul 26, 2008 | 03:15 PM
cool so ride without the bov? n all i got is my ls v chipped im like 2 hours away from my tuner which really sucks
Old Jul 26, 2008 | 03:16 PM
94delslo's Avatar
hmm. I know if you drive with your IC piping off you can over spin the turbo. Wouldn't removing the BOV be the same concept? or is that something completely different?
Old Jul 26, 2008 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 &raquo;</TD></TR><TR><TD CLASS="quote">cool so ride without the bov? n all i got is my ls v chipped im like 2 hours away from my tuner which really sucks</TD></TR></TABLE> same here... what part of tex u from bro?
Old Jul 26, 2008 | 06:46 PM
94delslo's Avatar
Houston area
Old Jul 27, 2008 | 10:07 AM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94delslo &raquo;</TD></TR><TR><TD CLASS="quote">hmm. I know if you drive with your IC piping off you can over spin the turbo. Wouldn't removing the BOV be the same concept? or is that something completely different? </TD></TR></TABLE>
No, you're right, you can. He can't go around punching the gas and whatnot, but it's a smaller leak compared to pulling the IC piping off and the turbo will still have some resistance so that he can drive normally and not have to worry about ruining the turbo.
Old Jul 27, 2008 | 11:24 AM
mtber's Avatar
Read Over https://honda-tech.com/zerothread?id=1544043
Old Jul 27, 2008 | 12:09 PM
hotrod99's Avatar
Default Re: having trouble picking up just boosted (mtber)
I forsee a blown engine post within a week
Old Jul 27, 2008 | 03:53 PM
boostedh23's Avatar
i agree
lurkin' eg
Dec 16, 2007 09:11 PM
B16Civic93
Mar 27, 2005 04:48 PM
juka
Dec 10, 2004 11:57 AM
jetpilot
Jul 30, 2004 08:52 AM
turbo*s2k
Mar 31, 2004 03:27 PM
