SR BB t28 having oil problems
Old Jul 26, 2008 | 10:34 AM
blk96coup's Avatar
Default SR BB t28 having oil problems
I bought this turbo used from a friend. I ran the feed line un-restricted for 1000 + miles not knowing it needed to be restricted. I then tore my motor down for a rebuild with forged parts and i now have a restrictor fitting in the turbo. I did change my oil return line to two 90 -10an fittings. Now this thing smokes like crazy. It drips oil out of my v-band off of the turbo and pushes oil into my hot side and my intake pipe. I took the turbo off and it has no shaft play still but the local shops say that it doesn't have oil seals. Is this true and if so why is my turbo leaking oil?
Old Jul 26, 2008 | 10:39 AM
VTECth1s's Avatar
Default Re: SR BB t28 having oil problems (blk96coup)
What size oil return and feed line are you using? I've read people having more success from having the oil restrictor just a few inches from the turbo. Or half way from the turbo and block.
Old Jul 26, 2008 | 10:42 AM
blk96coup's Avatar
Default Re: SR BB t28 having oil problems (VTECth1s)
-10an return and -6an feed
Old Jul 26, 2008 | 01:32 PM
thatblkguy's Avatar
-6 is to big -4 with a restrictor that turbo is more then likly toast
Old Jul 26, 2008 | 05:15 PM
blk96coup's Avatar
Default Re: SR BB t28 having oil problems (thatblkguy)
Anyone else with some knowledge of these turbos?
Old Jul 26, 2008 | 05:44 PM
postman's Avatar
-4 restricted
-3 unrestricted
-6 ls vtec feed
Old Jul 27, 2008 | 03:08 AM
blk96coup's Avatar
Default Re: SR BB t28 having oil problems (postman)
Alright, I have enough -4 laying around to run a new feed, but will my turbo be alright and not burn/leak oil once i do this?
Old Jul 27, 2008 | 07:27 AM
AmauryR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk96coup &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I have enough -4 laying around to run a new feed, but will my turbo be alright and not burn/leak oil once i do this?</TD></TR></TABLE>
don't know, put the line on and hope you didn't drive it around long enough to damage the seals. Hopefully it'll be alright. Also, with your return, couldn't you've used a straight and a 45 instead of 2 90's ? Or was it due to some manifold design, etc?
Old Jul 27, 2008 | 08:11 AM
TheShodan's Avatar
Moderator
The turbo was toast while it was unrestricted, and now you've made it worse using the 2 90 degree AN fittings. If it is a true ball-bearing cartridge, it is time for a new turbocharger. Get rid of the 2 90 degree angles or you'll be in the same position as before. On your next turbo, (if this is indeed for a Honda), then a .035" restrictor should be used for the feed line of a -3AN.
Call it a wrap on this turbo.
Old Jul 28, 2008 | 11:33 AM
thatblkguy's Avatar
which t28 do you have?
S14
s15
s15 spec R
GTIR
bubbleboy22
Jun 18, 2007 03:26 PM
Blkteg97
Nov 16, 2004 08:04 AM
slo_crx
Oct 12, 2004 05:51 PM
jacob_kohler
Sep 17, 2004 12:44 PM
z6
Jun 3, 2004 11:03 AM
