oil return on top of turbo or feed on top??helpppp
i have an SC34 and it looks like when the turbo is mounted the oil return line goes on top, the bigger hole is on top and when i connected the oil line kit the oil return was on top and is not long enough to do a u-turn and go down to the oil pan.
should the return be on top or is my turbo retarded?
Re: oil return on top of turbo or feed on top??helpppp (z6)
re-clock the turbo by loosening all of the 1/2" bolts.. DONT REMOVE THEM, just loosen them... then you can spin the turbo. The oil return should point stright down.
