Throttle Sticking- After acceleration
Old Jun 24, 2008 | 04:31 PM
ricertypeR's Avatar
Default Throttle Sticking- After acceleration
Hey everyone!
My throttle sticks a little bit after modest to heavy acceleration. Anyone on this site have an issue with this? The engine is a stock d16z6.
I searched under these topics and found nothing useful
Throttle
Throttle sticking
Also searched through my Haynes Repair Manuel, but the problem wasnt listed.
Any help would be greatly appreciated!
Old Jun 24, 2008 | 04:34 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Throttle Sticking- After acceleration (ricertypeR)
Dirty/sticky throttle body?
Old Jun 24, 2008 | 04:35 PM
vtecb18c's Avatar
sounds like your throttle cable it sticking somewhere...possibly a kink?
Old Jun 24, 2008 | 04:39 PM
ricertypeR's Avatar
Default Re: Throttle Sticking- After acceleration (vtecb18c)
Thanks for the replies!
I'll take the intake off tommorrow and check to see if the butterfly valve is dirty. I dont know if it could be a kink because the throttle cable has never been removed.
Old Jun 24, 2008 | 04:52 PM
vtecb18c's Avatar
the cable doesnt have to be removed its called wear and tear
Old Jun 24, 2008 | 06:09 PM
seadonkeyraypiss's Avatar
The problem could also be on the pulley for the throttle body plate (where the cable hooks into). There is a small grub screw under the pulley that the TB pulley rests on when your foot is off the gas pedal. If for some reason this screw backed up too far the TB plate would stick.
Old Jun 24, 2008 | 07:02 PM
Juan_Mitosis's Avatar
I have exactly the same symptom, after hard acceleration, or simply after pulling the foot off the gas too quickly, it gets stuck. I removed the TB one day and even sanded it a little bit, luibed it, removed and put back stuff on it, no replacing just taking off and on, and its not as bad now. I also adjusted my throttle cable a little tighter and it happens even LESS< but its' not gone. Good luck with this issue!
Old Jun 24, 2008 | 08:44 PM
frankie99si's Avatar
i would recomend wd-40 on the throttle return spring and where there is any movement on the tb if still persist get new tb cable
boostedteg1203
Jan 14, 2010 01:17 AM
EKSedAndy
Oct 10, 2007 01:09 PM
Nameless Warrior
Feb 1, 2007 08:58 AM
Slow_h22
Aug 1, 2004 03:25 PM
VTEC-DA
Dec 10, 2002 05:25 PM
