HELP, throttle stuck at wide open
my throttle is stuck in the wide open postion. the throttle cable itself, is very very slack. its not broken though. what could cause this? it was tight two days ago when i changed the oil.
Re: HELP, throttle stuck at wide open (Slow_h22)
welll i broke my lower tranny bolts through the casing and if i launch hard at all the whole engine will jerk forwards and backwards on the lower side and this could be the cause try to adjust the throttle cable.. with the little nuts that are there.. and if u try to move the throttle from the wide open position what happens.. is it the cable that is holding it there or is it the actual throttle that is stuck./
Re: HELP, throttle stuck at wide open (pane93civhb)
i had a problem similar to this once, when i installed my CAI. I accidentally slid the throttle cable off of the guide and made it very very slack. I dont know if this would be the answer for you
Re: (Slow_h22)
Problem solved. i decided i would take my aem cai off to have a better look at the throttle body, and guess what. that nice rubber diaghram from the bypass had been sucked into the throttle body. thanks aem for making a quality plastic product.
Nameless Warrior
02-01-2007 08:58 AM
