B16b with ls crank ?
Old Jun 12, 2008 | 01:45 AM
deadfish13's Avatar
Default B16b with ls crank ?
done some searching .
basically i getting b16b b18c blocks same ...jus stroked diff.
also i found b18c with ls crank setup.
so can i use an ls crank in the ctr / b16b block .
if yes what rods pistons CR ...i looking at ?
also with the ctr cam have valve to dome clearance issues
thanks
Old Jun 12, 2008 | 08:38 AM
vtecb18c's Avatar
Default Re: B16b with ls crank ? (deadfish13)
huh???
Old Jun 12, 2008 | 10:30 AM
inspyral's Avatar
Yes, you can run an LS crank in a B16B since LS and B16B(and B18C and B20B/Z) blocks have the same deck height. You would need to run LS length rods. Pistons are your choice, since the pistons from all the aforementioned blocks(as well as B16A) are interchangeable. To calculate your projected CR, use an online calculator like this one:
http://www.c-speedracing.com/h...c.php
You shouldn't have valve to piston clearance issues if you run an OEM VTEC piston(they have larger valve reliefs than OEM non-VTEC pistons) or aftermarket forged pistons(again, they come with larger valve reliefs). It's still a good idea to clay the engine to doublecheck the clearance, especially for larger cams or if you plan on running a lot of cam advance/retard settings.
Old Jun 16, 2008 | 01:14 AM
deadfish13's Avatar
Default Re: (inspyral)
hey thanks for the info
would such a swap make sense ?
b16b is a great motor .
but i dont rev when i drive ....i hardly ever pull 7500 rpm
so i was thinking about a using the ls crank and some cam gears/ intake to move the power band down . possible ?
or is the ctr cams gonna need the higher rpm ?
what about jus doing an ls/vtec ?
Old Jun 16, 2008 | 09:50 AM
inspyral's Avatar
The added displacement would yield more torque and additional power. It would essentially be the same as an LS/VTEC setup as far as displacement goes, but you would have the option of retaining the oil squirters and not have to run an external oil line to the head.
Old Jun 16, 2008 | 01:06 PM
deadfish13's Avatar
would i be able to also keep the girdle ? or would the crank have clearance problems
someone also told me if i use forged rods eg eagle , crower , srp etc , that they suppose to be able to handle the heat , so i can remove the oil squirters ?
does that make sense ?
Old Jun 16, 2008 | 02:01 PM
inspyral's Avatar
Yes, you can also keep the girdle. Yes, you don't technically need the squirters if running forged pistons(they're there to cool the bottoms of the OEM cast pistons, not the rods).
Old Jun 18, 2008 | 01:33 AM
deadfish13's Avatar
13.5 cr
ls crank
what hp range NA ? how much those ls vtec with ctr heads make well tuned .
basic i/h/e .
how reliable is the cr ..too high for daily driver ?
i will be using aem ems for tuning.
Old Jun 18, 2008 | 05:35 AM
CubanoRockr's Avatar
Default Re: (deadfish13)
wayy to high for a daily unless you can run c16 daily and a light car. (what car is this going in) a lot of factors in both power and dd ability, do you have a/c, power steering, have a lot of mountains/bridges in your area and mainly the weight of your car. the less weight is the better but a good recommendation is the b16a (pr3) pistons would yield a 11.3
depending on your cams, headwork PnP head etc... and quality of airflow on your header and exhaust 2.5" recommended. power from 195 - 220 give or take on the hp range, but this is considering a well matched set-up. what tranny do you have to go with this? it's a lot of factors G/L with the build
i'm actually doing something very similar, gsr block w/ls crank and b16 pistons on a gsr head and either bc stage 4 or skunk 2 pro 1 cams w a ported intake mani (blox or skunk2) and not quite sure of the header yet maybe a hytech replica or a used smsp etc...
Old Jun 18, 2008 | 08:02 PM
turbociv910's Avatar
i made 166whp on my straight b16b.
i am looking to do the same build- b20vtec
my question- ls cranks.. have to get rid of oil squirters?
Old Jun 20, 2008 | 02:15 AM
deadfish13's Avatar
Default Re: (turbociv910)
the research i did ...more or less say the oil squirters can remain ...just need to be bent out of the way . ? correct me if i wrong anyone
i think i will stay with a stock ctr head ...and the b16a pr3 was looking more reliable .
just wanted to know if 13.5 was "streetable"
car is an eg hatch. full accessorys NEEDED . car is my dd , so AC and PS is a MUST.
drive train ....act flywheel 12.5 lbs , competition clutch stage 4 kit .
currently i have a cable with hydro conversion .
but i have SiR box to drop in , y80 i think .
looking at getting an s4c , itr box .
gear lenghts ....
i love the gears of the current cable ...well suited to my driving.
SiR ...has a longer 4th ....dont know how this affect driving.
for an NA set up ...what gearing should be looking at if i keeping the revs down to 7500.
Can a Cable Box lsd fit into a SiR BOX ????????
any other comment / suggestion / advice would be appreciated.
thanks guys
Old Jun 21, 2008 | 08:31 AM
jdmralliart's Avatar
any update on the build?did you stick with the pr3 or pct?
Old Jun 26, 2008 | 03:22 AM
deadfish13's Avatar
Default Re: (jdmralliart)
not a build yet
just looking at some options.
found an old thread about a build using the ls in a gsr block.
interesting thing was the Golden Eagle Oil block off kit.
anyone have any views good or bad about leaving the oil squirters out when using the forged pistons and rods ?
where the heat goes ?
thanks
Old Sep 10, 2008 | 08:36 AM
deadfish13's Avatar
need some help with the rods for this build.
CRS5531A3D ...eagle long rod ...do i need pistons with raised wrist pins. Or will standard pistons work .
planning on using this rod for a better R/S.
any input is appreciated
thanks
sirekhatch
Feb 27, 2007 08:17 PM
nebulight
Nov 9, 2006 07:49 AM
EGcivicvtec
Feb 13, 2006 09:54 AM
whiplashEG6
12
Apr 2, 2004 03:28 PM
Nameless RB26
Feb 27, 2003 10:29 PM
