Has anyone ever seen or done this setup?
Old Jun 6, 2008 | 08:29 PM
boondocks1805's Avatar
Default Has anyone ever seen or done this setup?
Ok I am currently building a D15B and here is everything I have so far. I just wanted to see if anyone else has done/seen this and what i can expect.
CP pistons (9.0:1)
Crower Rods
450cc RC injectors
OBX fuel Rail
OBX FPR
255LPH Walbro Fuel Pump
P28 ECU (Socketed w/Hondata S100)
Hondata 4 BAR MAP sensor (I know 4 BAR is way over doing it, but it was free)
T3/T4 Turbo
Moshimoto Intercooler Kit
Gripforce Stage 3 Clutch w/Fidanza 8lbs Flywheel.
I will be pushing 10-12 PSI Regularly and 16 at the track. I haven't Replaced the Cam yet because I am having one built, also I will be using the Z6 tranny. I am asking if anyone has seen/done this setup because it is kind of hard to have it dyno'd right now due to the fact I am in IRAQISTAN at the moment. Thank you in advance for any input.
Old Jun 6, 2008 | 08:38 PM
instrument's Avatar
good luck with your answer, its good to see that someone presumably in the military has time to worry about stuff like this.
i think if i were over there the last though i had would involve building a motor.
free bump.
Old Jun 6, 2008 | 08:43 PM
Well seeing as how we do get off time occasionally......I use that spare time to get what little info I can...........
91DA-C
Jun 7, 2010 01:04 PM
00CIVICSITEIN
Mar 16, 2004 05:47 PM
Sh4rky
Mar 14, 2003 03:56 PM
RavageEJ6
Nov 10, 2002 09:42 AM
swpdb16
Oct 30, 2002 09:48 PM
