Has anyone ever seen or done this setup?
Ok I am currently building a D15B and here is everything I have so far. I just wanted to see if anyone else has done/seen this and what i can expect.
CP pistons (9.0:1) Crower Rods 450cc RC injectors OBX fuel Rail OBX FPR 255LPH Walbro Fuel Pump P28 ECU (Socketed w/Hondata S100) Hondata 4 BAR MAP sensor (I know 4 BAR is way over doing it, but it was free) T3/T4 Turbo Moshimoto Intercooler Kit Gripforce Stage 3 Clutch w/Fidanza 8lbs Flywheel. I will be pushing 10-12 PSI Regularly and 16 at the track. I haven't Replaced the Cam yet because I am having one built, also I will be using the Z6 tranny. I am asking if anyone has seen/done this setup because it is kind of hard to have it dyno'd right now due to the fact I am in IRAQISTAN at the moment. Thank you in advance for any input. |
good luck with your answer, its good to see that someone presumably in the military has time to worry about stuff like this.
i think if i were over there the last though i had would involve building a motor. free bump. |
Well seeing as how we do get off time occasionally......I use that spare time to get what little info I can...........
