Want to make 300-350 whp is this setup ok for that?
D16z6
---Block
Srp Pistons 9-1 .20 over bore
Eagle Rods
Nuformz block gaurd
---Head
RC 550CC Injectors
Over size + 1 mm Valves
Crower springs
Crower Retainers
Crower Stage 2 Turbo CAM
3 Angle Vavle Job
---Clutch
RPS 6 Puck Sprung
---Tunning
Hondata s200 From Jeff Evans
---Turbo
SC61 or SC50
Thats basically waht I was planing along wiht 2.5 inch down pipe and 3 inch straight exhaust. Do you think I could reach my goals out of a d16z6?
---Block
Eagle Rods
Nuformz block gaurd
---Head
RC 550CC Injectors
Crower springs
Crower Retainers
3 Angle Vavle Job
---Clutch
RPS 6 Puck Sprung
---Tunning
---Turbo
SC61 or SC50
Re: Want to make 300-350 whp is this setup ok for that? (00CIVICSITEIN)
If you haven't picked up the injectors yet...you have a great setup...my friend has a bubble w/ a verrrry similar setup...but used a 720cc injector...upgraded fuel pump...and switched the fuel lines -8 from tank -6 return...need to get yourself an aeromotive (or similar) fuel pressure regulator and a 3 bar map sensor too...I would definately do all that I mentioned before tuning...my friends setup made 405 to the wheels...being conservatively tuned! People do sleep on the single cams...I don't know why but they do.
