Weird problem
Old May 29, 2008 | 08:37 PM
Speed_1's Avatar
Default Weird problem
I had some water down in the cylinder where the spark plugs go , and it was causing my car to miss fire. I pump it all out and cleaned it up and as soon as i put it back my car ran a bit weird sounded like a WRX. I change the plugs and the wires and it runs more normal but, when i pull the spark plug wire out of cylinders one or two the car doesnt really change, but if i pull three or four it boggs down a bit like it suppost to. I was wondering what could be the problem anyone have any suggestions?
Old May 29, 2008 | 08:40 PM
z6hatchboy's Avatar
Default Re: Weird problem (Speed_1)
WRX sounds = wrong firing order. Find the firing order on your dizzy. Try searching it.
Old May 29, 2008 | 09:42 PM
Speed_1's Avatar
Default Re: Weird problem (z6hatchboy)
i have the right firing order. I did a compression test and all but cylinder 2 was at 220, cylinder 2 itself was at 205. its a 00 B16A. i recently changed the cap, rotor, PVC, Wires, Plugs, and Coil about 500 miles ago. It drive fine right now but i was curious way cylinders 1 and 2 wont drop the RPM's like 3 or 4.
Modified by Speed_1 at 8:12 AM 5/30/2008
Old May 30, 2008 | 07:11 AM
Speed_1's Avatar
anybody?????
Old May 30, 2008 | 07:18 AM
1CaMw0nDeR's Avatar
Default Re: (Speed_1)
How did you get water in there..??
Old May 30, 2008 | 07:29 AM
Speed_1's Avatar
i was cleaning up the motor, and i guess it leak through the spark plug cover, and through the wires. atleast i hope thats how it got there, other then that i dont see any other way.
Old May 30, 2008 | 07:30 AM
1CaMw0nDeR's Avatar
Does the car smoke at all..??
Old May 30, 2008 | 07:32 AM
Speed_1's Avatar
nope
Old May 30, 2008 | 08:28 AM
1CaMw0nDeR's Avatar
yeah so u probably just got water in there when u were cleaning it... did u change ur oil afterwards..??
Pudnite
Feb 11, 2018 04:46 PM
Kyle244R948
Aug 14, 2004 12:27 PM
nY's FiNeSt
11
Apr 12, 2004 01:28 AM
ThaReason
Nov 8, 2003 08:44 PM
