My car is not foring in the #2 and #3 cylinder help!!!!!!!!!!
Ok this is the deal, I just put a LS in my CRX and im having problems with the 2 and 3 cylinder. The thing is that when i start my car up, it idles ruff and I tested the injectors, changed the spark plugs, wires, cap and rotor. When i drove it yesterday i didnt have any problem, but when i started it this morning it was running right. I did a compression check and all cylinders are at 175. And i tryed a different distributor, and i tryed my buddies ECU and i changed the 02 sensor. Whats the problem??????
Re: My car is not foring in the #2 and #3 cylinder help!!!!!!!!!! (ThaReason)
Have you checked to see if there is spark at 2 & 3? Unplug the wire from the sparkplug and install another and ground it. Do they fire? If they do, make sure they are in the right place on the cap. I tend to reverse those two when I don't pay attention. The car will generally run, but not well.
If there is no spark on the test, I don't know, you have already tried the stuff I would replace under those conditions.
Yeah i tryed taking them out to see if the car dies out, but it doesnt. They have a little fire coming out of them. Thanx for the help though.
Anymore help?
Anymore help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaReason »</TD></TR><TR><TD CLASS="quote">Ok this is the deal, I just put a LS in my CRX and im having problems with the 2 and 3 cylinder. The thing is that when i start my car up, it idles ruff and I tested the injectors, changed the spark plugs, wires, cap and rotor. When i drove it yesterday i didnt have any problem, but when i started it this morning it was running right. I did a compression check and all cylinders are at 175. And i tryed a different distributor, and i tryed my buddies ECU and i changed the 02 sensor. Whats the problem??????</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Yeah i tryed taking them out to see if the car dies out, but it doesnt. They have a little fire coming out of them. Thanx for the help though.
Anymore help?</TD></TR></TABLE>
imma little confused with these two post...
the first post says that occasionally it runs rough when you first start the car and you 'feel' that cylinders 2&3 are at fault??? And the second post says that removing the plugs from 2&3 has no affect on how the car runs???
Re: My car is not foring in the #2 and #3 cylinder help!!!!!!!!!! (dirty_d_cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirty_d_cx »</TD></TR><TR><TD CLASS="quote">try switching the wires around
just a guess</TD></TR></TABLE>
it's 'running right'...
I tryed switching the wires around. I tryed everything possible with the distributor, and timing. Yesterday was my first day driving it since i did the swap, and it drove fine. But when i started up this morning it was idling rough and 2, and 3 were not even working. So basically now its only running on 2 cylinders.
BlakeJ53
09-03-2008 04:11 PM
