NEED HELPP
Old Aug 14, 2004 | 06:57 AM
Kyle244R948's Avatar
Default NEED HELPP
I have a week number 2 cylinder from misfire. I have took it to a acura dealership who works on my car all the time and they couldnt find how i was misfiring. They did a compression test, everything was fine. They switched my spark plugs, and they were fine, they switch spark plug wires and they was good, they also tried switching injectors from one to another and that wasnt the problem. So what i want to know is, has anyone else had this problem or does anyone have an idea of what could be causing me to misfire in cylinder 2... oh yeah and everytime i run threw a gear vtec does not kick on i think its because of the weak cylinder but im not sure???? someone please help a brother out here
Old Aug 14, 2004 | 07:03 AM
Sinbro2's Avatar
Default Re: NEED HELPP (Pwrd by HONDA R)
try the distributor cap where the #2 plug wire plugs in, make sure its in all the way or no cracks on the cap at all. also what about the plug itself
Old Aug 14, 2004 | 07:22 AM
Default Re: NEED HELPP (sinbro2)
all of that was checked by the acure specialist and everything was fine
Old Aug 14, 2004 | 07:42 AM
Sinbro2's Avatar
What is an"Acura Specialist?" Dude listen, do you know this guy who is working on your car? If he is such an "acura specialist" why can't he find your problem? I think that you should check this **** yourself, when working in the dealer you're pressed for time and corners are usually cut, which results in simple solutions being overlooked. Start from scratch and do in yourself to insure its done right!
Old Aug 14, 2004 | 08:01 AM
An acura/honda specialist is someone who has certifications for honda and acura engines, how am i suppose to check something that is internal, i dont think im gonna go and take my engine apart a look for whats wrong
Old Aug 14, 2004 | 11:44 AM
vtec.dc2's Avatar
how many miles on the car? and did this start happening out of nowhere or after certain work or incident? and have you modified anything ecu wise or ignition wise?
more details
Old Aug 14, 2004 | 12:27 PM
RinBlue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pwrd by HONDA R &raquo;</TD></TR><TR><TD CLASS="quote"> how am i suppose to check something that is internal</TD></TR></TABLE>
How do you know that your misfire is something internal?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pwrd by HONDA R &raquo;</TD></TR><TR><TD CLASS="quote"> i dont think im gonna go and take my engine apart a look for whats wrong</TD></TR></TABLE>
Well in that case live with misfire.
Hugo Montes
Mar 13, 2012 08:46 AM
aziaticvang
Jul 19, 2008 11:10 AM
Speed_1
May 30, 2008 08:28 AM
VvPeachyvV
Jun 6, 2006 12:49 PM
nY's FiNeSt
11
Apr 12, 2004 01:28 AM
