Throttle Question ?
How are you measuring 100% ? mecanically or with the tps outout voltage ? is the tps idle voltage set correctly, if it doesn't reach 100% output voltage for your car then maybe as before mentioned, the throttle cable needs ajusting or maybe the cam is the wrong ratio for your setup.
Drew96EJ
Nov 2, 2003 03:05 AM
