B16A-T help with oil pressure
Old Apr 25, 2008 | 07:41 AM
A BOOSTED CRX's Avatar
Default B16A-T help with oil pressure
hey h-t,
hopefully this will be an easy fix if anything is wrong BUT...
my crx has a b16a with turbo in it...it is tuned off s300 by anthony at av-engineering. Anyway, my oil light has come on i believe 3 times, when it does, the car shuts off...dunno why.
im letting the car idle as we speak...oil pressure is a little over 25psi and -17 in vacuum.
ive been driving the car before someone hit me, and it will drive perfectly fine until i slow down enough to where im hardly moving, in neutral...and the oil light will come on and just shut off...now i can just crank it back up and its fine and will drive, but whats the deal?
thx, and im about to drive it again...see if i can possibly make it do the same thing
ill let you know
any suggestions?
Old Apr 25, 2008 | 07:59 AM
ShortbusEK's Avatar
Default Re: B16A-T help with oil pressure (A BOOSTED CRX)
dumb ? but you do have enough oil in there??
oil pump going out...
oil pickup clogged for some reason..
where is the oil line for the turbo tapped into??
Old Apr 25, 2008 | 08:12 AM
Default Re: B16A-T help with oil pressure (ShortbusEK)
oil is full and golden
walbro 255 fuel pump...and no its not going out..brand new
not clogged
possibly plugs? it doesnt break up, so i dont think that would be it
just took it for a drive...RUNS PERFECT ...just idle- it will die out sometimes..
WTTTTTTTTTTFFFFFFFFFFFFFFFFFF
Old Apr 25, 2008 | 09:24 AM
ShortbusEK's Avatar
not your fuel pump... the oil pump.. if the oil light comes on oil pressure has dropped below safe levels..
Old Apr 25, 2008 | 10:46 AM
0bd1_Kanobe's Avatar
I agree on the oil pickup, drop the pan and take a look and see if everything is legit!
Old Apr 28, 2008 | 02:21 PM
ShortbusEK's Avatar
Default Re: (0bd1_Kanobe)
any update on this OP?? just curious what the problem is/was??
Supahr_Ed
May 27, 2006 11:51 AM
crxsiperf
Nov 23, 2005 04:36 PM
dominate9
Dec 15, 2004 05:51 PM
B18Flip
Apr 17, 2004 05:15 PM
sk8rmike
Sep 7, 2003 01:34 PM
