Driver side lower engine mount bolts spin in place...
Old Apr 18, 2008 | 03:18 AM
[ivi]'s Avatar
Default Driver side lower engine mount bolts spin in place...
I do believe whatever welds the bolts go into snapped. I soaked them for days with PB blaster knowing this could happen, but they still snapped
The bolt that goes through the mount seems to have a nut on the end (19mm), but it's not budging either, this bolt isn't reverse threaded, is it? I noticed it's threaded on both ends from the HELM manual...
Any suggestions from more experienced people with this problem?
Old Apr 18, 2008 | 04:40 AM
[ivi]'s Avatar
Default Re: Driver side lower engine mount bolts spin in place... ([ivi])
bump, any quick hacks to get this [freak]er off?
Old Apr 18, 2008 | 05:32 AM
ballinboosi's Avatar
do you have a pry bar? You just got give it a lil boost is all. Sometimes they are a pain in the ( . ) to get out. Or you can try my method and use your foot and legs
Old Apr 18, 2008 | 05:37 AM
[ivi]'s Avatar
Default Re: Driver side lower engine mount bolts spin in place... (ballinboosi)
The thing is, the nut on the end of that bolt is VERY shallow, I tried fitting a breaker bar to it, and it has ALOT of play. If I use a breaker bar, it's going to strip the nut, I know it.
Heres a pic of the mount for those who don't know:
Old Apr 18, 2008 | 05:49 AM
geebs's Avatar
the nut that goes to the mount is a pain.. you need a big breaker bar or an air impact gun.. the two that go into the framerail sometimes break the nuts that are welded in there.. if you want to take them out you have to cut a hole enough to get your finger or a wrench in there to hold the nut. some people say they got a long prybar under the head of the 14mm bolt and pried down to create pressure.. ive never had luck that way.
Old Apr 18, 2008 | 05:57 AM
[ivi]'s Avatar
Default Re: Driver side lower engine mount bolts spin in place... (geebs)
Yeah I've spent two days with an impact gun on that end bolt, it just doesn't want to budge.
I was afraid someone would say "cut a hole", I'm just not equipped for that.
Old Apr 18, 2008 | 07:20 AM
[ivi]'s Avatar
I'd rather just cut the mount off than cut a hole in that beam. I'm putting a stronger engine in and don't want the frame to deteriorate because of some cheap-*** tig welds Honda did, so no holes. I'll jus snip the rubber out if I can't get this end nut off.
Looks like wheel hop until I get a replacement drilled in.
Old Apr 23, 2008 | 06:10 AM
[ivi]'s Avatar
Anyone know how these have ben replaced in the past without compromising the integrity of the frame?
Old Apr 23, 2008 | 07:04 AM
Bakeoff's Avatar
Why not just undo the 14mm blots that connect it to the frame rail? No offense, but this isn't rocket science...it's a nut or a couple bolts...
Old Apr 23, 2008 | 07:18 AM
[ivi]'s Avatar
Default Re: (Bakeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">Why not just undo the 14mm blots that connect it to the frame rail? No offense, but this isn't rocket science...it's a nut or a couple bolts...</TD></TR></TABLE>
Those are the bolts that are spinning in place. The nuts that hold those bolts are tig welded to the frame on the inside, and you can't get to them unless you cut the frame open, and that's what I'm trying to avoid because that area is a major stress point in the frame. Those tig weld snapped, and now both just spin in place. Nothing on a Honda is rocket science, duh.
Old Apr 24, 2008 | 07:40 PM
geebs's Avatar
Default Re: ([ivi])
tighten those 14mm back up and leave that mount in there.. youll need it for another swap if you want ac...
just take that 19mm nut off.. long breaker bar.. its got lock tite on it
Old Apr 26, 2012 | 10:22 AM
hockeydave's Avatar
I'm having the same issue and I need to replace my A/C belt. How did you fix this?
Thanks!
-Dave
Old Apr 26, 2012 | 10:56 AM
beecee18's Avatar
Default Re: ([ivi])
I agree, and if your putting a more serious motor in the future simply slam some ES vibration mount bushings in there before putting back together.
Swansen
13
May 20, 2020 11:56 AM
knightrider2009
Dec 21, 2009 05:42 PM
MI4$DC5
Mar 26, 2006 04:43 PM
elmalouno
10
Jul 13, 2003 09:42 PM
216.226.142.95:27016
Jun 29, 2003 02:27 PM
