how to remove front engine mount
Old Dec 19, 2009 | 04:54 PM
knightrider2009's Avatar
New User
Default how to remove front engine mount
hi,
I have a 95 accord. the front engine mount is broken, i tried to replace it.
I can remove the 3 bolts attached to the engine, but the through bolt is so tight. I tried to use all my 155lb body strength, I still can't get it loose.
Anyone know why this thing is so tight? and how can i loose it? thanks.
Old Dec 19, 2009 | 05:02 PM
bobinator5000's Avatar
Default Re: how to remove front engine mount
Grind the bolt.
Rent a compressor, buy an air ratchet. It'd make your life easier.
Get a cheater bar on it if you can get it in the right spot.
Otherwise, find the fattest heaviest guy you can get and promise him a pizza if he can undo the bolts. The earth will tremble, the car will shake, the bolt will tink, and you will be a happy 155 pound geek. ^.^
Old Dec 19, 2009 | 11:59 PM
nus_dogg's Avatar
Um.... If I'm not mistaken, isn't there a welded nut on one side? Make sure you're loosening the correct side which will be the bolt and not the welded nut.
Old Dec 20, 2009 | 12:32 PM
davey5300's Avatar
make sure you tell the big dude that the bolts is on the left side of the bracket.And give chines food instead. hehehe
but for real use a cheater bar, or torque bar, and spray some WD-40. and make sure you turning left.
Old Dec 20, 2009 | 01:53 PM
JonJuan's Avatar
Icon6 Re: how to remove front engine mount
I have a related question.....hopefully someone answering this will know...I'm new here btw so hello to all...I looked in the FAQ's and maybe didn't look good nuff but I'm swapping my '94 5speed and was gonna replace all the mounts while it was out....I just wanna know how many mounts total there are...I keep seeing one for autos but I'm not sure if there is a rear mount for the manual.......
Also.....anyone know where I can order a whole set and maybe save some coinage????
'Preciate any help!!!!
'94 Accord LX (stock....for now)
Old Dec 20, 2009 | 09:59 PM
bseriescrxsi's Avatar
yes there is a rear in 5 speed.....unless there is something wrong with it which i doubt dont bother replacing it...other then that there are 3 others ones......i have seen higher end racing mount packs but usually they are sold separately
Old Dec 20, 2009 | 10:06 PM
JonJuan's Avatar
I thought so...well I figured with the eng/trans out do it now but i'll look at it and see if its bad i know one is for sure....thanks for the info!!!!!
Old Dec 20, 2009 | 10:19 PM
bsivoljr's Avatar
Originally Posted by knightrider2009
hi,
Yeah Im dealing with a bolt right now that is a POS...Upper Control arm 2nd bolt will not budge? Makes no sense but is stopping me from getting my CD5 on the road. Sucks. First the lower control arm was being a pos so I had to get a recipricating electric saw to cut it off! Problem is I can't just cut this control arm bolt off because it goes into the frame of the vehicle Which is not visible. The reason I have to take it off is because I messed the thread up where the spindle arm control and upper connect. So I cant just reuse it Maybe I'll just Cut the ball jointand replace that way I can just leave the stupid arm and bolt in?...Anyways goodluck
USE PB BLASTER, HIT THE BOLT WITH A HAMMER MAKING SURE NOT TO BEND BOLT OUT OF SHAPE THE PUT YOUR GUNS TO WORK JUST TO SHAKE UP THE OLD BUILD UP.
Old Dec 20, 2009 | 10:38 PM
JonJuan's Avatar
@bsivoljr i had the same issue with my '94.....what i did was put a jack on the LCA and jacked it up, took te bolts off and wailed away with a rubber mallet til it all loosen up.....took about 15 min but it came out....ball joint too....
Old Dec 21, 2009 | 05:42 PM
New User
Thanks all for the help.
yeah, the nut is welded onto the bracket, but the nut doesn't look like it's welded. need to loose the bolt side, which is the side with very little space, and that was why i didn't try to loose the bolt in the first place.
I had to remove the radiator fan to open up a little bit more space. and I broke the 3/8" extension when I try to unbolt the bolts from the crossbar, so i think i will use 1/2" next time.
again thank you all for the help, i'm very happy now. Fry eggplant for everybody.
potatointegra01
Mar 30, 2015 09:24 PM
[ivi]
12
Apr 26, 2012 10:56 AM
MSU2000
Sep 8, 2010 12:00 PM
lmike6453
Jun 4, 2008 07:15 PM
216.226.142.95:27016
Jun 29, 2003 02:27 PM
