Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
master kill switch revisited
Old Apr 14, 2008 | 02:56 PM
Phoenix_ITR's Avatar
Default master kill switch revisited
i just spent the last hour and a half reading all of the various posts regarding master kill switches and i actually think i'm now more confused than ever.
from looking at my car (94 dx coupe), it seems that there are two inputs into the underhood fusebox: one from the alt and one from the batt. right now i only have a two post kill switch and i was wondering if i could cut both of those + cables to the underhood fusebox and run them to the SAME post on the switch. obviously i would then use the other post for the returns to the fusebox. i've tried disconnecting both of those cables while the car is running and it kills power. is this a safe way to do this? thanks!
Old Apr 14, 2008 | 04:00 PM
ewaugh's Avatar
Default Re: master kill switch revisited (Phoenix_ITR)
I tried using a two post and realized that it wouldn't work the way I wanted to wire it. I put a ford starter solendoid in series with the alternator and a hot off the fuse box to open and close the solenoid. The only problem was that the solenoid wasn't rated for constant use. After a few electrical problem someone yells accross the garage at nashville that my car was smoking. The solenoid let the smoke out, and man was there a lot of it...
Buy a longacre 4 terminal and follow the instructions. I'd have to look to see exactly how I wired mine now.
Old Apr 14, 2008 | 04:21 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phoenix_ITR &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if i could cut both of those + cables to the underhood fusebox and run them to the SAME post on the switch. </TD></TR></TABLE>
NO. You should not do this. Your alternator will still be hot after you turn off the kill switch.
Instead, buy a 4 post kill switch. Cut the battery (only!) with one, and cut the ignition wire with the 2nd one. This will disconnect the battery and stop the engine.
-Chris
Old Apr 14, 2008 | 04:57 PM
Default Re: master kill switch revisited (Chris F)
what about starter wiring? can i simply wire the starter directly to the batt as it is stock?
Old Apr 14, 2008 | 05:23 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phoenix_ITR &raquo;</TD></TR><TR><TD CLASS="quote">what about starter wiring? can i simply wire the starter directly to the batt as it is stock?</TD></TR></TABLE>
No. Take Battery + to the switch, then from the switch to the OEM Batt+ terminal.
Old Apr 14, 2008 | 05:25 PM
granracing's Avatar
There are a few ways to do this, but here's how I diagramed it.
http://www.goaheadtakethewheel....html
Old Apr 14, 2008 | 05:36 PM
Default Re: (granracing)
that diagram helps a lot -- it appears you have the pos bat cable coming from the switch, going through a distribution block, then continuing on to both the fusebox and the starter.
thanks for your help everyone!
Old Apr 17, 2008 | 09:13 AM
Lo-Buck EF's Avatar
Default Re: (Phoenix_ITR)
this is the one i have. i gotta look at how i have it tho. i cant remember.
edit:after looking at the diagram on dave's site, mine is done like that. the switch dumps to ground via the resistor to chassis ground.
Modified by Lo-Buck EF at 2:37 PM 4/18/2008
Old Jun 4, 2008 | 08:52 PM
Jeff_B's Avatar
Default Re: (Lo-Buck EF)
I just bought a Longacre 4-post switch (2 large terminals and 2 small terminals) but am still confused on how to wire it correctly on my Integra (Even after going through a few threads).
From the battery there is one cable going from the + terminal to the starter and another cable going from the + terminal to the underhood fusebox. Should both of these be switched or just one?
granracing - The link to your diagram isn't working anymore. Would you mind reposting it?
Old Jun 4, 2008 | 11:53 PM
117's Avatar
117
I bought a 6 pole kill switch from Pegasus and wired it up exactly as shown in the instructions (main switch cuts +12V, normally closed cuts ignition, normally open grounds alt output to ground through the provided resistor), and it's worked perfectly ever since I installed it.
Old Jun 5, 2008 | 03:54 AM
granracing's Avatar
No problem Jeff. The link is for the diagram; on the bottom of the page there's a "Click Here for Next Page" link which discusses more information on the subject. One thing I haven't put on it yet is the differences in kill switches themselves. I previously bought a plastic version like the one shown in the picture earlier in this post and about every year or two had to replace it. I then switched to a metal version of the kill switch which holds up much better.
Old Jun 5, 2008 | 09:04 AM
GPNY's Avatar
I used a 2 pole Flaming river switch and wired it like this:
It works well.
I leave the front breaker closed for daily driving and open for situations that may require a kill switch.
Old Jun 5, 2008 | 10:38 AM
Jeff_B's Avatar
Default Re: (GPNY)
Thanks Dave! That diagram is exactly what I was looking for. So now I just need to buy a distribution block/connector to split the wire coming off the switch into the starter and fuse box.
TegraGSXR
Aug 20, 2011 04:56 PM
boostedb20z
Mar 23, 2009 05:59 PM
domsb16
Dec 9, 2007 04:23 PM
underpressure02
Apr 23, 2007 08:42 AM
servion
Feb 12, 2005 04:47 AM
