This bolt is being a pain in the a$$
I am installing inserts on my 99 Si, and need to drop the motor a bit to get the torque mount out.
I have to loosen up the driver side top mount to lower it but my PS line is in the way. I have no way to access it.
I can get the one on the right (in this pic) using an extension, but the not the one on the left.
http://i102.photobucket.com/albums/m112/kaluwa3/MM004.jpg
What should I do?
http://i102.photobucket.com/albums/m112/kaluwa3/MM004.jpgWhat should I do?
Well how do I go about doing that? What screws/nuts do I have to remove to take off the pump? I don't wanna disconnect any lines because it will make a mess.
it's the very top thing on the front of your engine.
That hose that's in your way.....that goes to your PS pump. Follow that.
Then look on the left hand side of that bracket that holds the pump in place. You can figure it out from there.
Razr2, whoa, there are other options before removing youe PS and making a mess of things.
how about a swivel adapter, have you tried that? you can get to it with a swivel adapter and a extension.
then there is alittle elbow grease, you can bend the hard line just alittle to clear what you need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">Razr2, whoa, there are other options before removing youe PS and making a mess of things.
then there is alittle elbow grease, you can bend the hard line just alittle to clear what you need.</TD></TR></TABLE>
Thats what I was thinking. I'd rather do that and not make a mess.
Where can I get a swivel adapter, and do you think it would fit under it? Not much clearance there? I'm gonna go try using an open end wrench and see if I can get it in there.
I'll let you know. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razr2 »</TD></TR><TR><TD CLASS="quote">
I'll let you know. Thanks</TD></TR></TABLE>
unless you have a opened end wrench that acts like a socket wrench and is jointed, i would avoid using it since it's pointless too. as for the swivel, you can pick them up at any parts store for a couple of bucks. they according to your wrench.
yeah you can bend the line alittle to get it where you need (whether it's up, down, left, or right). the eg lines are alittle different, so i don't have to go through your problem.
to do it like everyone else is saying, you would have to release the tension on the belt, slide it out, unbolt the pump from the motor yet still keep the line attached.
to much work if you ask me.
I'm going to go out on a limb here and suggest something different... how about you jack the engine up by the oil pan a little bit just to get the weight off the mounts on that side. Then move the PS fluid reservoir, unbolt the bracket for the reservoir, and then unbolt the spaceship mount and slide it out of the way. That way the motor can move down and you don't have to F with the PS pressure line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edmek4 »</TD></TR><TR><TD CLASS="quote">just move the ps pump its only 2 bolts </TD></TR></TABLE>
no it's more than 2 bolts and to much work is involved. i'm taking it your new to Honda stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">I just used an extension and bent the hose a little bit.</TD></TR></TABLE>
agreed! i double checked my pressure line and it's quite bendable. atleast bendable enough to fit what's needed to get the job done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 »</TD></TR><TR><TD CLASS="quote">I'm going to go out on a limb here and suggest something different... how about you jack the engine up by the oil pan a little bit just to get the weight off the mounts on that side. Then move the PS fluid reservoir, unbolt the bracket for the reservoir, and then unbolt the spaceship mount and slide it out of the way. That way the motor can move down and you don't have to F with the PS pressure line.</TD></TR></TABLE>
he's going to have to do this anyway because the motor need support once the mount is moved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">no it's more than 2 bolts and to much work is involved. i'm taking it your new to Honda stuff.
It'll take 5 minutes... I have done it numerous times before. Removing the AC compressor, now that is a pain in the ****.
</TD></TR></TABLE>It'll take 5 minutes... I have done it numerous times before. Removing the AC compressor, now that is a pain in the ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
It'll take 5 minutes... I have done it numerous times before. Removing the AC compressor, now that is a pain in the ****. </TD></TR></TABLE>
granted, it still unnecessary though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">he's going to have to do this anyway because the motor need support once the mount is moved.</TD></TR></TABLE>
Touché
Touché
get some rags, support the engine then, remove the line, it only 2 bolts, do what you have to do then put the line back on, it not that hard, maybe a little messy but come your working on a car you are gonna get a little dirty
gl
gl
dpkelly
Jul 10, 2011 12:51 PM
undagroundrican
Dec 19, 2007 07:33 PM
BeerBaron105
12
Dec 13, 2004 03:24 PM
MiKeAhOwSkI
11
Jul 29, 2004 07:21 AM
