ej2 cluster problem.
Old Mar 20, 2008 | 11:16 AM
dannycraq's Avatar
Default ej2 cluster problem.
this is really weird, now this happened before my swap, i think when the other engine blew it might have something to do with it. but i cant figure out what the hell is wrong with it. could it be an electrical shortage? is it an ecu problem? cause my ecu was fine. also when i rev my engine, the mph gauge moves which doesnt make sense to me other than the fact the ecu is manual now when it used to be auto.
heres my cluster when i turn the key one click
heres my cluster when engaged and ready to be turned over
even when i turn the car on, it goes a little higher to 40 mph
im assuming this is an electrical short or maybe a sensor is in the wrong port? :?
can i adjust this?
Old Mar 20, 2008 | 11:35 AM
dannycraq's Avatar
nobody got a clue?
Old Mar 20, 2008 | 11:40 AM
faxshatch's Avatar
Default Re: (dannycraq)
Um the only thing thta i could geuss is that there is a short sum where in the circuit!
Old Mar 20, 2008 | 11:41 AM
faxshatch's Avatar
Default Re: (faxshatch)
If it turns out to be the speedo itself ive got one with 160k on it and am willing to sell it for like 20 bucks
Old Mar 20, 2008 | 11:49 AM
dannycraq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faxshatch &raquo;</TD></TR><TR><TD CLASS="quote">Um the only thing thta i could geuss is that there is a short sum where in the circuit!</TD></TR></TABLE>thats what i was thinking and pondered picking up a cluster to plug n play and see if itll do the same thing
cause when i shift the car into gear the mph also go up
also pm'd about your cluster
Old Mar 20, 2008 | 12:14 PM
dannycraq's Avatar
Old Mar 20, 2008 | 04:31 PM
faxshatch's Avatar
Yea man sorry about that i kinda sumhow got threads mixed up... Dnt ask me how
Old Mar 20, 2008 | 04:38 PM
dannycraq's Avatar
ill still buy your cluster, what it do.
Old Mar 20, 2008 | 05:19 PM
nix94delsol's Avatar
have you ever taken your needle off?
Old Mar 20, 2008 | 06:36 PM
dannycraq's Avatar
never touched the needle, took out the whole cluster, but never touched the needle. could that be it?
Old Mar 20, 2008 | 06:47 PM
JDM_SOHC's Avatar
checked ur VSS..??
Old Mar 20, 2008 | 06:58 PM
dannycraq's Avatar
have no clue what that is, mind schoolin me on that bro.
Old Mar 20, 2008 | 07:02 PM
dannycraq's Avatar
oh the variable speed sensor
well
check this out, my car used to be automatic, and it did that too.
Old Mar 20, 2008 | 07:05 PM
dannycraq's Avatar
just unplugged the VSS on top of the tranny, and it did it without the VSS being plugged in. =/
Old Mar 20, 2008 | 07:17 PM
JDM_SOHC's Avatar
VSS - Vehicle Speed Sensor....
Check the pin on ur ecu as well.. Not sure what ecu ur running but im running OBD1 P28 and plug B slot 10 is the VSS vehicle speed sensor..
Make sure to check the wires on the plug as well, sometimes corrosion happens on there an u dont even notice it under ur intake so don't think to clean it off... GL
Old Mar 20, 2008 | 07:29 PM
dannycraq's Avatar
im running a p06 converted to manual. i think its probably that, cause you're the only one with a somewhat logical answer, guess ill just take it in.
Old Mar 20, 2008 | 07:32 PM
JDM_SOHC's Avatar
Keep in mind bro, all VSS's are interchangable as well between D an B series.. Meaning you can throw a B16, GSR, D16Z6 sensor it dont matter... Makes it easier to find one knowing that, just incase u need a new one...
Old Mar 20, 2008 | 07:34 PM
dannycraq's Avatar
so i can just swap out that sensor going into the top of the tranny and im good?
not the one you screw into the case, but the one on the harness?
Old Mar 20, 2008 | 07:36 PM
dannycraq's Avatar
also, is it possible to just put this off until i get a new VSS and just drive the speed of other cars? cause
Old Mar 20, 2008 | 07:38 PM
JDM_SOHC's Avatar
lol yeah it cant get much more broke besides just no speedo at all, but thats kinda similar to ur situation now... dude u can get one at a junkyard for like $10 bucks an 9/10 times the one u pick up is gonna still be good, i've gone through tons of those between myself an friends, their dime a dozen cuz of the selection of cars to get'm off of... 92-00 civics 94-01 integras that had vtec...
Old Mar 20, 2008 | 07:40 PM
JDM_SOHC's Avatar
its only one bolt that holds it down, its a goofy lookin 10mm bolt... the other 2 bolts hold the VSS together, dont be mislead in thinking they hold it to tranny cuz they dont... u take out that one 10mm bolt an just shimmy it while pulling up "not pulling on wires" but actually gripping the VSS an just maneuvering it up an it comes right out...
Old Mar 20, 2008 | 07:49 PM
dannycraq's Avatar
yea good lookin out bro, im pretty much certain thats what it is, cause my mph revs with my tach as see in the flash video from my celly
it did that when i had my auto tranny in too
the VSS that came on my new tranny is pretty much new from what the guy told me, so if it aint that, its gotta be the plug going into the vss and if aint that, its my ecu
Old Mar 20, 2008 | 07:52 PM
JDM_SOHC's Avatar
aftermarket tach huh... now im sorta leaning towards wantin to bet money its ur VSS or wiring lol... an yeah bro i got u, i kno sometimes this kinda ***** confusing an trust me when i first was learnin this **** it was a pain in the *** when nobody was tryna help an i couldnt find a [freak]in picture to save my life... so yeah man dont worry bout it, an MOST DEFINITELY check that VSS an the wiring... If you had a continuity tester you could test the plug to see if its gettin a faulty signal or anything but thats a lil more involved... Just give the basic **** a check first than lemme kno wassup...
Old Mar 20, 2008 | 07:59 PM
dannycraq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote">aftermarket tach huh... now im sorta leaning towards wantin to bet money its ur VSS or wiring lol... an yeah bro i got u, i kno sometimes this kinda ***** confusing an trust me when i first was learnin this **** it was a pain in the *** when nobody was tryna help an i couldnt find a [freak]in picture to save my life... so yeah man dont worry bout it, an MOST DEFINITELY check that VSS an the wiring... If you had a continuity tester you could test the plug to see if its gettin a faulty signal or anything but thats a lil more involved... Just give the basic **** a check first than lemme kno wassup...</TD></TR></TABLE>yea i got one of those. as for the aftermarket tach, i hooked that up properly, no where near the vss LOL
i just shot it to a blue wire on my drivers side under the hood.
so yea ima check that out, and ill hit you through a pm, im bookmarkin this now.
kikla
Dec 21, 2011 01:18 AM
demonicivis1320
13
Sep 26, 2011 08:26 PM
SetInMotion
Mar 29, 2009 06:05 AM
sneakerfern
Nov 6, 2008 03:41 PM
TwoSaints
14
Jun 16, 2003 05:46 PM
