Block Guard
Old Mar 4, 2008 | 09:43 PM
SilverWarrior's Avatar
Default Block Guard
Is it possible to install a block guard without taking the whole motor out? Is it possible by just taking off the cylinder head.
Old Mar 4, 2008 | 11:28 PM
b19coupe's Avatar
Default Re: Block Guard (SilverWarrior)
When you install a block guard, it distorts the cylinder bores. The bores need to be machined round again. But if you so desire, you can pull the head and install the block guard in the car. Pound away
Old Mar 5, 2008 | 02:21 AM
Default Re: Block Guard (b19coupe)
what do you mean by distorts the cylinder bores? So this shouldn't be done without re-machining it?
Old Mar 5, 2008 | 03:38 AM
turboZChatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">When you install a block guard, it distorts the cylinder bores. The bores need to be machined round again. But if you so desire, you can pull the head and install the block guard in the car. Pound away </TD></TR></TABLE>
Learn something new every day
Old Mar 5, 2008 | 08:32 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverWarrior &raquo;</TD></TR><TR><TD CLASS="quote">So this shouldn't be done without re-machining it?</TD></TR></TABLE>
No, it really should not. What makes you think that a block guard is necessary for your application?
Old Mar 5, 2008 | 09:10 AM
2001B18C1GS-R's Avatar
A block guard is necessary for what anyway
Old Mar 5, 2008 | 06:51 PM
hmongxcuz's Avatar
i dont see the point of ever using block guards, just spend a little more and get sleeves
unless your set up is stock dont need to do nothin to the cylinders
Old Mar 5, 2008 | 07:13 PM
98vtec's Avatar
moderator emeritus
is a block guard even the same material as the block? if its not, then it will not have the same expansion properties as it is heated. end result? think about it.....
Old Mar 5, 2008 | 07:32 PM
Runnerdown's Avatar
Default Re: Block Guard (98vtec)
I have always thought that the block guard was a joke. Cylinder pressure and heat cracks sleeves, not side to side movement in the block. Several sleeving companies make theirs open deck just like honda does.
Where I work, we have done many 4-500whp turbo cars on stock sleeves with no problems.
Old Mar 5, 2008 | 08:13 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Block Guard (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Where I work, we have done many 4-500whp turbo cars on stock sleeves with no problems.</TD></TR></TABLE>
synapse = car heaven
Seriously, a block guard is just not required.
Old Mar 5, 2008 | 09:27 PM
smileycvc's Avatar
Default Re: (hmongxcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongxcuz &raquo;</TD></TR><TR><TD CLASS="quote">i dont see the point of ever using block guards, just spend a little more and get sleeves
unless your set up is stock dont need to do nothin to the cylinders</TD></TR></TABLE>
A little more? A block guard only cost like 250 installed and thats with machining. Tell me where you can even buy just sleeves for that much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">I have always thought that the block guard was a joke. Cylinder pressure and heat cracks sleeves, not side to side movement in the block. </TD></TR></TABLE>
Unless its a B20.
Old Mar 5, 2008 | 10:39 PM
vteczone's Avatar
Default Re: (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">
Unless its a B20. </TD></TR></TABLE>
i bought my raw sleeves from camp1320 back in 2004 for like $290.. they r not branded like darton or GE but i would still go for that sleeves than the block guard.
Old Mar 5, 2008 | 11:36 PM
smileycvc's Avatar
Default Re: (vteczone)
I agree that sleeves are better than a blockguard but to say that sleeves only cost a little more than a blockguard, is not quite accurate.
Old Mar 6, 2008 | 10:17 AM
98vtec's Avatar
moderator emeritus
depends on what sleeves you are referring to.
replacement liners are like 400 installed.
boofunit
Jul 31, 2011 11:50 PM
AlienKrOZ
Jul 19, 2010 03:07 PM
mustbenu
Jan 12, 2005 08:27 AM
Nextelbuddy
Jan 6, 2004 10:08 PM
McFly
Nov 15, 2002 09:37 AM
