head removal help
Old Jul 31, 2011 | 10:25 AM
boofunit's Avatar
Default head removal help
Im going to be installing a block guard before i turbo and was wondering if there were any guides on removing/re-installing a gar head?
Old Jul 31, 2011 | 10:57 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: head removal help
if you need help taking a head off and on... you shouldn't even be attempting to install a block guard
Old Jul 31, 2011 | 12:43 PM
ryguy2588's Avatar
^^^^ x2
Haynes manual will show how to remove a head, but I would take it to a machine shop and have them put it in or just not run a block guard.
Old Jul 31, 2011 | 12:56 PM
98integralsB18's Avatar
i would skip on the block guard if i were you.
Old Jul 31, 2011 | 01:54 PM
96accordsir's Avatar
you also need a bore and hone and cause install of a block guard distorts the cylinders a bit..
Old Jul 31, 2011 | 02:26 PM
civickiller's Avatar
+1
Old Jul 31, 2011 | 04:02 PM
boofunit's Avatar
how do u suggest i learn then?
boofunit's Avatar
why skip it?
Old Jul 31, 2011 | 04:13 PM
sanman000719's Avatar
block gaurds do not strengthen the cylinders at all
what it might prevent is cylinder walk (float) but thats about it.
man i made 598 on a stock gsr block thats totally stock with no gaurd, and that motor has 40 passes on it and is still alive.
e85 is one of the best ways to keep a stock motor togather it really is a great fuel to run
Old Jul 31, 2011 | 11:50 PM
wantboost's Avatar
Who is Mr Robot?
have someone with you that knows what they're doing...
sivtechatchy
Jan 13, 2020 11:03 AM
crazyboy
May 1, 2010 11:27 PM
sivtechatchy
Mar 6, 2009 03:45 AM
mustbenu
Jan 12, 2005 08:27 AM
