Redline Problem!!!!!!!
alrite i have a 2000 honda civic si and wen i redline it in second gear it redlines at what it is exposed to but then in third gear it redlines at 7k and in fourth at about 6k. the day it started doing this idling at like 3k but would go back down to regular after a few seconds so we tried using my friends ecu to see if that would make it stop idling weird and it did so we put the regular ecu on it and that when it started to redline all messed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000jdmsi »</TD></TR><TR><TD CLASS="quote">alrite i have a 2000 honda civic si and wen i redline it in second gear it redlines at what it is exposed to but then in third gear it redlines at 7k and in fourth at about 6k. the day it started doing this idling at like 3k but would go back down to regular after a few seconds so we tried using my friends ecu to see if that would make it stop idling weird and it did so we put the regular ecu on it and that when it started to redline all messed up.</TD></TR></TABLE>
idle problems.... wtf are you changing ECU's for?
Thats an IACv/FITv/ vaccuum issue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000jdmsi »</TD></TR><TR><TD CLASS="quote">cause when we put in my friends p2p it idled at 1k and i cleaned my iacv way before it started messing up</TD></TR></TABLE>
p2p is for the D16y8, so im assuming this is the canadian civic SI?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000jdmsi »</TD></TR><TR><TD CLASS="quote">no its not its a usdm b16a2 hes jus running that ecu because it is swapped into an ex</TD></TR></TABLE>
So your running a Dual Cam motor with a single cam ECU?
And you wonder why its running like crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
Thats an IACv/FITv/ vacuum issue
X2 That! Take a look at you injectors to but i think that wouldn't be far up in the power band just a suggestion
</TD></TR></TABLE>X2 That! Take a look at you injectors to but i think that wouldn't be far up in the power band just a suggestion
WHY
WHY
So, tell me this ur friend had p2p running in his car what engine is in his car... is it a Y8 or a B16A2? I'm lost you need to explain better and what ECU are u running in ur car?
ok i have in my car rite now a p2t my friend has the p2p and yes he is runnin a p2p in his b16a2 and it runs perfect i put his ecu in my car to see if that would fix my idling problem and it did but wen i put my ecu bac in it started idling wierd again so i cleaned out my iacv and now its fine. Now i jus need help to see y it redlines at random rpms
k.gren
Nov 2, 2011 10:25 PM
Vtecme92
Aug 28, 2010 10:29 PM
Vtecme92
Jul 16, 2006 05:44 PM
Laurence
Apr 30, 2004 03:29 PM
