irratic idle need help ASAP video inside!!!!
i have a 97 ej8 with a b18b swap it idles really ruff and struggles in first and second, i have no idea were to start i just got done rebuilding it and now this, the only cel is for the iacv which when i hook it up makes the car idle at 4000 rpms, please help this is my dd and it is running like ****!!!
http://youtube.com/watch?v=8CLoX461UMg
Re: irratic idle need help ASAP video inside!!!! (97ekb18b)
bumo i just went out and rechecked the dizy firing order and it was wrong i fixed that it idles good now now it just is lacking power im assuming the cams are off alil, and i do have a vacuum leak do you think that would cause it to have low power and pop back threw the intake alil bit...
do you think if i timed the crank by using a screw driver in the num1 cylinder but i was turning it clock wise and not counter clock wise it would throw the timing off one tooth and cause it to lack power.....
Re: (YELLOW_DUCK)
its currently unhooked dont you guys read the thread.... if i hook it up i idle at 4000 rpms, i have know idea as to what to check i can not figure it out....
make sure you don't have the connector for iacv switched with another from the harness, some sensors share the same clips and i think (but i'm not sure) the iat sensor is one of them.
my car threw a cel and idled like **** when i had these switched around, the tps and map sensor connectors can also be switched around ....
Re: (thursday)
i tryed swithching the tps and map around and it idled fine then if i gave it gas it back fired bad also i am only throwing a code for the iacv which is not hooked up, if the plug was wrong for the ias im sure it would throw a code to......
Re: (97ekb18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b »</TD></TR><TR><TD CLASS="quote">i tryed swithching i am only throwing a code for the iacv which is not hooked up</TD></TR></TABLE>
? iacv is not hooked up, how do you expect it to idle if it isn't sending anything to the ecu? Did you build a blockoff plate for the iacv or is it just hot plugged in?
Re: (thursday)
yea its not plugged in because when it is it idles at 4000 rpms constent so do you think this might be why it idles funny........
crxspoonb18c5
06-18-2008 02:21 PM
allshownogo
03-09-2008 08:46 AM
