endtank design/efficiency
Old Jan 16, 2008 | 03:59 PM
robbbby's Avatar
Default endtank design/efficiency
i'm in the process of cutting up the endtanks for my intercooler, i was planning on doing a 'backdoor' style, with pipe welded to the back of the endtanks at 90 degrees.
before cutting though i figured i'd take a look at other smoother backdoor designs.
i found a webpage and came across this, seems like it would be a ton better for airflow
http://www.are.com.au/feat/techtalk/tt1001w.JPG
it would take alot more time to design than the 5 minutes it took to do regular endtanks.
i'm just curious though, will a design like this be that much more efficient, is it worth spending the extra time fabbing something a little smoother up or are the gains not really worth it.
thanks
Old Jan 16, 2008 | 04:25 PM
weiRtech's Avatar
OG Fabricator
it all depends on how much power you are planning on making i'd think. with higher pressures flow might make a difference, but if you're only aiming for 300hp, i don't think it will hold you back to have something with a 90 degree angle coming out the back of it. i think there are even better designs than that one as well. this is one i like:
not mine btw.
how is the sr20 mani coming?
Old Jan 16, 2008 | 04:52 PM
robbbby's Avatar
Default Re: (weiRtech)
that design is interesting, it still comes in at 90 degrees but flares, nice to see different designs.
haven't started the manifold yet, just finishing up the collector so i can make a jig to position it in the exact spot i want.
i actually wanted to ask you, where did you get the fitting that fits into your regulator for your backpurge setup. i can't find anything with pipe thread on one side that also threads into the regulator.
keto
Nov 21, 2009 01:01 PM
BLKTeg94
Mar 8, 2006 11:38 AM
Jcup315
Oct 7, 2005 09:14 AM
Keith P
Mar 29, 2005 04:25 AM
dohcMONSTER
Feb 3, 2005 02:01 PM
