Is this gonna be worth it?
Old Oct 7, 2005 | 04:52 AM
Jcup315's Avatar
Default Is this gonna be worth it?
My friend is selling his intercooler because he just got a new one. His old one is slightly larger than the one I have now. Its a little thicker and it has a couple more horizontal prongs than mine has. Am I going to see a big enough difference in power for it to be worth it if I upgrade just slighty larger? Sorry I don't know the exact dimensions of the intercoolers but his is bigger which hopefully will make a difference either way. Thoughts and helpful opinions please.
Old Oct 7, 2005 | 05:51 AM
Rod Short's Avatar
Default Re: Is this gonna be worth it? (Jcup315)
Bigger may not always be better. With air-to-air intercoolers, the idea is to get as much surface area (height x width) while keeping the intercooler core as relatively thin as you can.
If you compare two exact sized intercoolers of different thicknesses, the thicker intercooler will definitely support more hp (because there's more opportunity for heat transfer as air passes thru the fins), but it will also be more of a brick. What I mean by that is that it will be harder for air to pass through it because it's so thick.
With that in mind, a 4 to 5-inch thick intercooler core may be better suited for the race track (you can push a lot of air through at 100-mph) while a 3 to 3.5 inch would be a lot better for stop n' go daily driving.
Bar and plate designs are also considered to be better than tube and fin because they 1) can handle higher boost loads and 2) are more resistant to damage from road hazards. Tube & fin designs, however, are lighter and cheaper in price.
Core efficiency (part of which is determined by above) , pressure drop and fin design & aerodynamics are other factors, too . . . but don't really relate to your situation since you don't really know what you have.
Hope that helps you. Good luck with your new intercooler.
Old Oct 7, 2005 | 07:54 AM
Axel Foley's Avatar
Default Re: Is this gonna be worth it? (Rod Short)
i have the apex-i gt intercooler, what do you think of that intercooler for a 600whp street car?
Old Oct 7, 2005 | 08:14 AM
Jcup315's Avatar
yeah that did help, I know that the one i might get off him isn't 4-5 inches...i think mine is 3 and his is 3 1/2
Old Oct 7, 2005 | 09:14 AM
Rod Short's Avatar
Glad that did, Jcup
As for the Apexi, I have no clue. Sorry
pjean_07
Aug 2, 2010 03:02 PM
.RTErnie
Oct 8, 2005 05:16 PM
dohcMONSTER
Feb 3, 2005 02:01 PM
JM Performance
Dec 30, 2003 07:40 PM
igo4bmx
Jul 13, 2003 09:50 PM
