dump tube question and a few more
Old Jan 12, 2008 | 10:57 PM
pbzhb's Avatar
Default dump tube question and a few more
currently i have no dump tube on my waste gate. I wanted to know how important it is to have a dump tube and if I can get away with not having one. I would also like to know where I can find articles about tuning your car to high psi and change the timing so it last longer.
thanks,
Old Jan 13, 2008 | 04:20 AM
TDogg Teg's Avatar
Default Re: dump tube question and a few more (pbzhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbzhb &raquo;</TD></TR><TR><TD CLASS="quote">currently i have no dump tube on my waste gate. I wanted to know how important it is to have a dump tube and if I can get away with not having one. I would also like to know where I can find articles about tuning your car to high psi and change the timing so it last longer.
thanks,
A dumptube is is good to have to keep your engine bay free from hot sooty exhaust gases and excessive heat from the wastegate. In addition, routing your dumptube back into the downpipe or exhaust reduces backpressure and the probabtlity of boost spiking.
As far as tuning, do a search, Im pretty positive you can find some very insightful info. Or PM mtber from phearable.net.
Old Jan 13, 2008 | 04:35 AM
DaveF's Avatar
Default Re: dump tube question and a few more (TDogg Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDogg Teg &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jan 13, 2008 | 04:38 AM
blackeg's Avatar
Default Re: dump tube question and a few more (DaveF)
i view a dumptube as a necessity, even if it routes back into the downpipe. ive seen cars pick up 20-30+ hp from adding a dumptube. those gasses are bad news to get back into the intake manifold for making power.
my dumptube cost literally 20 dollars to make. an 8 dollar flange and a 12 dollar piece of pinch bent 1.5" mild steel
Old Jan 13, 2008 | 07:35 AM
xenocron's Avatar
A proper dump tube in the right application is the best dollar per horsepower you can spend on a turbo setup
vesperfx
Sep 18, 2008 02:44 AM
huge230
May 3, 2007 10:53 PM
G-Phi
May 13, 2005 07:21 PM
nd94cx
Sep 11, 2004 01:23 PM
yellow blur
May 30, 2002 08:41 PM
