Problem and question with routing my fmic piping
Old Dec 24, 2007 | 01:53 PM
mitsuman's Avatar
Default Problem and question with routing my fmic piping
This is what i got to work with coming out the bottom.
Now only thing i can think of is to route through the top but that leaves my piping really close to the manifold.
Or i can route a back door set up but that wont work because my intercooler is too long.
any tips?
Old Dec 24, 2007 | 02:39 PM
urbansi's Avatar
Default Re: Problem and question with routing my fmic piping (mitsuman)
yeah my first thought was going to be back door, look at some F22 set ups, they have the turbo set like you do in picture 2 and then A pipe that runs over the top. its hard to explain
somewat i mean
what chasis is his in?
Old Dec 24, 2007 | 04:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Problem and question with routing my fmic piping (urbansi)
i think the up and over with wrap may be your best bet, or hack off the end tank and make a back door?
Old Dec 24, 2007 | 05:08 PM
boosstboy's Avatar
Default Re: Problem and question with routing my fmic piping (boostedcivicsir)
here are pics of mine, u just can't have a washer resevoir , but you can have fog lights (ek) the shop i was working for did custom pie cut piping all the way from turbo-t-body. it took like 6 hours to just fab up lol. cost; not sure, i worked there so i just paid for material at cost of course
my turbo, not pictured obviously, runs a t04s cover with a 90 bend off compressor. i still run my stock bumper reinforcement bar. it is L notched on the back side against the IC, and slightly C notched were pipes run out of ic. all piping is 2.5" except 2.75" charge pipe.
Modified by boosstboy at 7:31 PM 12/24/2007
Old Dec 24, 2007 | 05:09 PM
m R g S r's Avatar
why does your oil pan look like it is a lot lower than the bottom of the rad support? is that correct like that? i don't remember mine being that low
Old Dec 24, 2007 | 05:11 PM
GraphiteAccord's Avatar
Default Re: Problem and question with routing my fmic piping (m R g S r)
Weld a 45 onto the compressor housing.
Old Dec 24, 2007 | 05:20 PM
mitsuman's Avatar
Default Re: Problem and question with routing my fmic piping (boosstboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosstboy &raquo;</TD></TR><TR><TD CLASS="quote">i'll post up pics of mine, u just can't have a washer resevoir , but you can have fog lights (ek) the shop i was working for did custom pie cut piping all the way from turbo-t-body. it took like 6 hours to just fab up lol.</TD></TR></TABLE>
how much did they charge you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">why does your oil pan look like it is a lot lower than the bottom of the rad support? is that correct like that? i don't remember mine being that low </TD></TR></TABLE>
im not sure. it does look low in that picture. might just be the picture . + my front cross member is dented up a bit. just remembered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">Weld a 45 onto the compressor housing.</TD></TR></TABLE>
aah no i dont want to do that, 45 welded on housing=ugly turbo
Old Dec 24, 2007 | 05:24 PM
PA MATT's Avatar
I just had a 90 welded onto my compressor housing. Looks professional and much better than running a charge pipe up and over the "frame rail"
Old Dec 24, 2007 | 05:38 PM
mitsuman's Avatar
Default Re: Problem and question with routing my fmic piping (PA MATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT &raquo;</TD></TR><TR><TD CLASS="quote">I just had a 90 welded onto my compressor housing. Looks professional and much better than running a charge pipe up and over the "frame rail"</TD></TR></TABLE>
i guess i dont have much of a choice now do i.
thanks all.
Old Dec 24, 2007 | 06:00 PM
Schister66's Avatar
Man U FTW
i have the same manifold and i run it like you have in the first picture. My next step is to weld a 90* elbow on the compressor housing or get an 90* coupler
...is that the Silver Surfer?
Old Dec 24, 2007 | 06:13 PM
SD_Lurker's Avatar
HT White Ops
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
...is that the Silver Surfer?</TD></TR></TABLE>
You bet your bottom dollar it is!! Mitsu PM me lets get you that 3 bar map!
Old Dec 24, 2007 | 06:16 PM
mitsuman's Avatar
Default Re: (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">
You bet your bottom dollar it is!! Mitsu PM me lets get you that 3 bar map!</TD></TR></TABLE>
confirmed, yes it is.
lol i pm'd you like 2 days ago or something. i want to send you money!!
PM"D
Old Dec 24, 2007 | 06:32 PM
boosstboy's Avatar
Default Re: (mitsuman)
pics up.
Old Dec 25, 2007 | 06:55 AM
97grnrs's Avatar
Default Re: (boosstboy)
i would just run it from the top.. thats how i did mine with no problems.. heat wrap it if ur concerned about temp.
Old Dec 25, 2007 | 07:23 AM
BrothaSit's Avatar
i used a radiator hose off a ford pickup work like a charm and cheap too
Old Dec 25, 2007 | 07:48 AM
ebp 99 si's Avatar
Default Re: (akitomoto)
i have mine routed up and over and it fits....but you have to cut the hole out a lil bit and you loose your washer tank
Old Dec 25, 2007 | 12:47 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (ebp 99 si)
it seems that those manifolds are more of hassle than anything, every person i see with one has all sorts of problems with oil lines and charge pipes
Old Dec 25, 2007 | 01:04 PM
PA MATT's Avatar
Default Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">it seems that those manifolds are more of hassle than anything, every person i see with one has all sorts of problems with oil lines and charge pipes</TD></TR></TABLE>
The charge pipes aren't really that big of a deal. Weld a 90 onto the compressor and it's just like any other setup.
Old Dec 25, 2007 | 03:15 PM
mitsuman's Avatar
it will pay off in the long run my friend!
Old Dec 25, 2007 | 03:40 PM
eh3 93's Avatar
I ended up going this route as well.
Old Jan 2, 2008 | 09:25 AM
mitsuman's Avatar
Default Re: (eh3 93)
Ended up getting a 90 welded onto the housing. looks clean, and keeps the piping to minimum instead going up and over.
Thanks guys.
bart2546
Mar 5, 2007 06:20 PM
MJobe
Nov 5, 2006 10:02 PM
guywitaDA
Feb 13, 2005 10:15 AM
5thgencivic
Dec 25, 2003 08:40 AM
KStuned
Feb 6, 2003 01:45 PM
