FMIC piping question, and methods.
Old Nov 5, 2006 | 07:16 AM
MJobe's Avatar
Default FMIC piping question, and methods.
I am doing a turbo kit install and it is on a 91 integra i basically got the passinger side piping all figured out but i am hella confused on how the drivers side is even going to work , a have a firend that said to maby use some sort of flex pipe to make the crazy bend that a DA needs has anyone ever used these?
Old Nov 5, 2006 | 08:14 AM
MJobe's Avatar
Default Re: FMIC piping question, and methods. (JOBEYYYYY)
bump for some opinions ,
Old Nov 5, 2006 | 08:18 AM
b18sihatch's Avatar
you cannot use flexpipe as intercooler piping
Old Nov 5, 2006 | 09:00 AM
Turbo EH2's Avatar
* B A N N E D *
Default Re: FMIC piping question, and methods. (b18sihatch)
on my old set up we torced part of the subframe to make a small hole, then we simply ran a u bend. Putting my flame suit on because someone might bitch about safety
Old Nov 5, 2006 | 09:36 AM
b18sihatch's Avatar
Default Re: FMIC piping question, and methods. (Turbo EH2)
you can cut a hole and have it boxed in for structual integrity.
Old Nov 5, 2006 | 01:39 PM
MJobe's Avatar
got any pics? im intrested in seeing how you ran it thanks for the advice
Old Nov 5, 2006 | 01:44 PM
pgmatt's Avatar
Posting pictures of your turbo/mani setup would help alot.You can run it through the windshield washer fluid hole,backdoor intercooler etc.Post some pics and maybe we can help
Old Nov 5, 2006 | 04:44 PM
riceball777's Avatar
theres 4 ways that i know of for the DA
1 run both pipes into the passanger side hole next to the battery (long pipes, sloow spool, bad idea)
2 run the pipe into the wiper bottle (most common)
3 cut a hole into the driver side frame nest to the two hook
4 cut a hole into the radiator support next to the radiator on the driver side (very short ic piping)
i did #4
most setups you will need to get an after market crossmember. i'm running the fullrace one.
Modified by riceball777 at 2:02 AM 11/6/2006
Old Nov 5, 2006 | 10:02 PM
MJobe's Avatar
Default Re: FMIC piping question, and methods. (riceball777)
i figured out a way, i will post pics tomarrow.
95civlx
Jun 2, 2010 10:45 AM
bart2546
Mar 5, 2007 06:20 PM
joshcivic00
Welding / Fabrication
Jul 18, 2005 09:29 PM
guywitaDA
Feb 13, 2005 10:15 AM
mike1114
Jun 3, 2003 06:23 PM
