Problem and question with routing my fmic piping
This is what i got to work with coming out the bottom.
Now only thing i can think of is to route through the top but that leaves my piping really close to the manifold.
Or i can route a back door set up but that wont work because my intercooler is too long.
any tips?
any tips?
Re: Problem and question with routing my fmic piping (mitsuman)
yeah my first thought was going to be back door, look at some F22 set ups, they have the turbo set like you do in picture 2 and then A pipe that runs over the top. its hard to explain
somewat i mean
what chasis is his in?
somewat i mean
Re: Problem and question with routing my fmic piping (boostedcivicsir)
here are pics of mine, u just can't have a washer resevoir , but you can have fog lights (ek) the shop i was working for did custom pie cut piping all the way from turbo-t-body. it took like 6 hours to just fab up lol. cost; not sure, i worked there so i just paid for material at cost of course
my turbo, not pictured obviously, runs a t04s cover with a 90 bend off compressor. i still run my stock bumper reinforcement bar. it is L notched on the back side against the IC, and slightly C notched were pipes run out of ic. all piping is 2.5" except 2.75" charge pipe.
Modified by boosstboy at 7:31 PM 12/24/2007
why does your oil pan look like it is a lot lower than the bottom of the rad support? is that correct like that? i don't remember mine being that low
Re: Problem and question with routing my fmic piping (boosstboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosstboy »</TD></TR><TR><TD CLASS="quote">i'll post up pics of mine, u just can't have a washer resevoir , but you can have fog lights (ek) the shop i was working for did custom pie cut piping all the way from turbo-t-body. it took like 6 hours to just fab up lol.</TD></TR></TABLE>
how much did they charge you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">why does your oil pan look like it is a lot lower than the bottom of the rad support? is that correct like that? i don't remember mine being that low </TD></TR></TABLE>
im not sure. it does look low in that picture. might just be the picture . + my front cross member is dented up a bit. just remembered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord »</TD></TR><TR><TD CLASS="quote">Weld a 45 onto the compressor housing.</TD></TR></TABLE>
aah no i dont want to do that, 45 welded on housing=ugly turbo
I just had a 90 welded onto my compressor housing. Looks professional and much better than running a charge pipe up and over the "frame rail"
Re: Problem and question with routing my fmic piping (PA MATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT »</TD></TR><TR><TD CLASS="quote">I just had a 90 welded onto my compressor housing. Looks professional and much better than running a charge pipe up and over the "frame rail"</TD></TR></TABLE>
i guess i dont have much of a choice now do i.
thanks all.
Man U FTW
i have the same manifold and i run it like you have in the first picture. My next step is to weld a 90* elbow on the compressor housing or get an 90* coupler
...is that the Silver Surfer?
HT White Ops
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">
...is that the Silver Surfer?</TD></TR></TABLE>
You bet your bottom dollar it is!! Mitsu PM me lets get you that 3 bar map!
Re: (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker »</TD></TR><TR><TD CLASS="quote">
You bet your bottom dollar it is!! Mitsu PM me lets get you that 3 bar map!</TD></TR></TABLE>
confirmed, yes it is.
lol i pm'd you like 2 days ago or something. i want to send you money!!
PM"D
PM"D
official honda whore
Re: (ebp 99 si)
it seems that those manifolds are more of hassle than anything, every person i see with one has all sorts of problems with oil lines and charge pipes
Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer »</TD></TR><TR><TD CLASS="quote">it seems that those manifolds are more of hassle than anything, every person i see with one has all sorts of problems with oil lines and charge pipes</TD></TR></TABLE>
The charge pipes aren't really that big of a deal. Weld a 90 onto the compressor and it's just like any other setup.
Re: (coptzer)
it will pay off in the long run my friend!
5thgencivic
12-25-2003 08:40 AM
KStuned
02-06-2003 01:45 PM
