Engine Overspeeding!!!! Lend me your ears!!
Old Dec 21, 2007 | 10:38 PM
GSE980's Avatar
Default Engine Overspeeding!!!! Lend me your ears!!
okay so Im leaving base my engine starting tapping out on the rev limiter with no thorttle. SO I shut it down when I started troubleshooting. I noticed a black plastic peice on the firewall was snapped. So I held it in place and my friend lightly revved it and it was back to normal but I have to replace this peice does anybody know what its called or how much this peice is???
Old Dec 21, 2007 | 10:49 PM
jasony0630's Avatar
76.26.106.124
any pics?
Old Dec 21, 2007 | 11:03 PM
bm5's Avatar
bm5
Default Re: Engine Overspeeding!!!! Lend me your ears!! (GSE980)
pics ?
Old Dec 21, 2007 | 11:34 PM
GSE980's Avatar
the pic I have of my engine bay the part is cut off
...its a plastic piece on the firwall that allwos the cable to pass through....
Old Dec 22, 2007 | 12:00 AM
loclowd's Avatar
Default Re: (GSE980)
Bump for a fellow Air Warfare Qualified
Old Dec 22, 2007 | 06:39 AM
Jonknee's Avatar
Default Re: (loclowd)
You're talking about the throttle cable hole in the firewall right? just go to a junkyard and get one.
Old Dec 22, 2007 | 07:36 PM
GSE980's Avatar
yeah the throttle cable hole.....I need a quick fix till wedsday all shops are closed
Old Dec 22, 2007 | 07:39 PM
Cln94EG1's Avatar
Try Using Vice grips to hold the cable Hillbilly Style lol
Old Dec 22, 2007 | 07:53 PM
GSE980's Avatar
YEAH!!! anything smaller though I tried using a small hose clamp but that didn't work. I guess vice grips will work..'
I tried using duct tape..it didn't work
you know the saying if you cant duct it F%$# it
Old Dec 22, 2007 | 07:58 PM
Cln94EG1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSE980 &raquo;</TD></TR><TR><TD CLASS="quote">YEAH!!! anything smaller though I tried using a small hose clamp but that didn't work. I guess vice grips will work..'
you know the saying if you cant duct it F%$# it</TD></TR></TABLE>
Ya but that cable wants to move back and forth when u step on it so im thinking Vice Grips would work but dont clamp down too hard u just want to hold the outside cable not the cable inside
Old Dec 22, 2007 | 09:08 PM
GSE980's Avatar
no the cable goes through a housing which plugs into the firewall this snapped making the cable slack which is making it rev high and not de accelerating....but if i clamp the housing the cable will still be able to move and will hold it at the right angle for no slack....I was also thinking about tightneing the bracket so tight that there is no slack in the calee but I odnt know if this would work or would it idle right I guess ill try the vice grips
Old Dec 22, 2007 | 09:09 PM
Cln94EG1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSE980 &raquo;</TD></TR><TR><TD CLASS="quote">no the cable goes through a housing which plugs into the firewall this snapped making the cable slack which is making it rev high and not de accelerating....but if i clamp the housing the cable will still be able to move and will hold it at the right angle for no slack....I was also thinking about tightneing the bracket so tight that there is no slack in the calee but I odnt know if this would work or would it idle right I guess ill try the vice grips</TD></TR></TABLE>
Let me know how it works
Old Dec 23, 2007 | 10:23 AM
GSE980's Avatar
hey got another question...if i rder a new throttle cable will this peice include with it or is it separate
Old Dec 23, 2007 | 10:27 AM
Cln94EG1's Avatar
It should come with it my cousin ordered one and were waiting to find out as well
Old Dec 23, 2007 | 10:34 AM
egsleepercivic's Avatar
it comes with the piece
Old Dec 24, 2007 | 09:59 PM
GSE980's Avatar
I tried the vice grips the plastic piece is not the problem..
the wire is birdcaging inside the rubber sheath not allowing it to drop back down to idle
Old Dec 24, 2007 | 10:02 PM
vegas hoe's Avatar
what kind of motor is it on?
i have a 98 dx one that you can have since it is christmas.
Old Dec 24, 2007 | 10:06 PM
93egSLEEPER's Avatar
Default Re: (vegas hoe)
ZIP TIES FTW
Old Dec 26, 2007 | 08:07 PM
GSE980's Avatar
Its a GSR I went to the junk yard and picked one up for 30 bucks and also got a one piece black headlights also...then a 00 GSR rolls in theft recovery hooked up guy is elling it to me for 2500....YAY
Old Dec 26, 2007 | 08:18 PM
vegas hoe's Avatar
which junk yard did you go to?
Old Dec 28, 2007 | 02:36 PM
GSE980's Avatar
honda club on main
Babykinns
Apr 3, 2013 09:13 AM
hondateg10
Sep 21, 2007 12:28 PM
NoVALude
Jun 18, 2006 01:31 PM
philosofy1
Jul 21, 2005 03:37 PM
