engine priming, whats the best method.
Old Dec 13, 2007 | 09:49 AM
dem0nk1d's Avatar
Default engine priming, whats the best method.
so me and my brother are building our first engine together. i would like to know what's the best way to prime the engine on startup. we are using good amounts of assembly lube, but i know this just wont cut it on the first start.
Old Dec 13, 2007 | 10:23 AM
Crazydave's Avatar
Default Re: engine priming, whats the best method. (dem0nk1d)
since the oil pump is driven directly off the crank, disconnect the distrubutor, and crank the starter until oil pressure builds up. shouldn't take more than a few seconnd
Old Dec 13, 2007 | 10:48 AM
Lubo_25's Avatar
Default Re: engine priming, whats the best method. (Crazydave)
by the textbook...
Old Dec 13, 2007 | 02:07 PM
Bjorn20's Avatar
Default Re: engine priming, whats the best method. (Lubo_25)
why not just pull the ecu fuse?
Old Dec 13, 2007 | 04:00 PM
Lubo_25's Avatar
Default Re: engine priming, whats the best method. (Bjorn20)
more than one way to skin a cat right??
Old Dec 13, 2007 | 06:53 PM
LastGenEK's Avatar
Lubos point was for the motor not too start
Be sure there is oil psi(and dont forget to put oil in it )
Old Dec 14, 2007 | 10:57 AM
Lubo_25's Avatar
Default Re: engine priming, whats the best method. (LastGenEK)
hahaha...ive seen a guy forget to put oil in a 4.6l mustang he packed his things up that day...lol
Old Dec 14, 2007 | 11:29 AM
4g hatch's Avatar
if you dont have a oilpressure guage take the valve cover off and turn it over until you see oil fly out. sometimes the get airlocked u may take out the allenplug and pour some oil in there
Rod.
Jul 18, 2005 09:16 PM
IloveNewt
Mar 18, 2004 11:21 PM
dc2pffsssttt
Mar 7, 2003 01:42 PM
rotten
Feb 10, 2003 07:02 AM
