25 CELs?
ok so i hooked up the computer to the hondata to figure out what the code was, and it turns out there was 25 different CELs at once. another thing that was a bit wierd was the datalogging was completely wrong. like the vss was at 436 mph, which is obviously wrong. what would be causing this all to happen. any ideas are appreciated
ya i checked all the cables. the light came in all of a suddon when i was driving. the car sounds and acts the same. i also noticed that the knock sensor code was going but when i look through the settings the knock sensor is dissabled. just seems alittle strange
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude »</TD></TR><TR><TD CLASS="quote">ok so i hooked up the computer to the hondata to figure out what the code was, and it turns out there was 25 different CELs at once. another thing that was a bit wierd was the datalogging was completely wrong. like the vss was at 436 mph, which is obviously wrong. what would be causing this all to happen. any ideas are appreciated</TD></TR></TABLE> Your ECU is Possessed!!! Lol.. Write down all the codes, then reset the ecu and see which ones come back, then go from there. Is ur car obd1 or obd2? Could be the codes were never cleared from the ecu.
Pull the cover off and make sure the chip is fully in the socket. Then make sure all the connections on the board look good, something came loose or blew it sounds like.
Is the LED on the hondata box on or flashing?
