CEL with Hondata?
Old May 25, 2003 | 05:38 AM
Chiovnidca's Avatar
Default CEL with Hondata?
I got my Hondata system hooked up and the CEL is on. It has no codes stored and it runs fine. Is this normal?
Old May 25, 2003 | 07:24 AM
TREVER's Avatar
Default Re: CEL with Hondata? (Chiovnidca)
No it should work as normal.
Old May 25, 2003 | 07:49 AM
pills_PMD's Avatar
it sounds like the cable between the ECU and interface box is whack. the connector that is soldered in the ECU may be in backwards...
do you have a pocket programmer?? can you burn a new ROM to test that??
try cutting J1 and returning to stock specs to see if that makes the cel go away.
but i would put my money on that cable between the interface box and ecu.
what stage is it the hondata?
Old May 25, 2003 | 10:56 AM
Chiovnidca's Avatar
If I click the "error codes" button in the HondaLogger software it say it has a code 23. My "94" Civic doesn't have a knock sensor. Maybe the Hondata ECU I got is from a model that has one? Do any of the OBD1 P28 ECUs have a knock sensor input?
Old May 25, 2003 | 11:01 AM
Chiovnidca's Avatar
Default Re: (pills_PMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pills_PMD &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like the cable between the ECU and interface box is whack. the connector that is soldered in the ECU may be in backwards...
what stage is it the hondata?</TD></TR></TABLE>
The interface box is working, it runs fine also. If I burn a stock rom, and disconnect the interface box there is no CEL. Very odd. It's an s200 system.
kardal86
May 24, 2010 08:59 PM
nonvteclude
Nov 24, 2007 07:02 PM
danny98r
Jan 16, 2005 07:51 AM
g5r
Sep 3, 2003 10:16 AM
VisualAutoMotoring
Jul 28, 2003 10:47 AM
