Boost not kicking in...vacuum leak?
Old Jun 22, 2002 | 05:14 PM
Etylorcen's Avatar
Default Boost not kicking in...vacuum leak?
Just filled up on some 91 and not getting any boost. My boost gauge isnt reading anything either so I think the fmu isnt seeing any boost either so its not providing the fuel I need. Any ideas?
Old Jun 22, 2002 | 05:26 PM
civictypenos's Avatar
Default Re: Boost not kicking in...vacuum leak? (Etylorcen)
do you feel any boost?whats your set up?do you show vaccum on your boost gauge,what does it say,we need more details.
Old Jun 22, 2002 | 05:44 PM
Etylorcen's Avatar
Default Re: Boost not kicking in...vacuum leak? (civictypenos)
Drag3 kit. Not feeling any boost at all. My boost gauge isnt showing any vacuum at all. I have the bov, fmu, fpr, and boost gauge all t'd off together.
Old Jun 22, 2002 | 05:48 PM
you should show about vaccum at idle,down around 22 or so,if your not showing vaccum,then you might have a pinch in the line going to the boost gauge,and if your not feeling boost,then you have a leak somewhere,intercooler piping,or your wastegate is stuck open ,or you have a leak in the exhaust system before the turbo.is the kit new?has it ever shown any boost
Old Jun 22, 2002 | 11:53 PM
Etylorcen's Avatar
The kit worked perfectly before. I think the problem is with the vacuum lines. If the fmu isnt reading boost correctly then the boost shouldnt kick in w/o the fuel right?
Old Jun 22, 2002 | 11:56 PM
Arturbo's Avatar
Better than steak
25 Year Member
You can still have boost with no fuel. But you will probably have no motor either.
art
Old Jun 23, 2002 | 12:42 AM
Etylorcen's Avatar
Default Re: Boost not kicking in...vacuum leak? (Arturbo)
Any idea what it is then?
Old Jun 23, 2002 | 12:52 AM
Arturbo's Avatar
Better than steak
25 Year Member
I really think its your intercooler pipes. Go and check every hose connection and pull on it to verify they are on.
art
Old Jun 23, 2002 | 01:34 AM
Etylorcen's Avatar
Ill recheck my pipes first thing tommorow morning. So you think the boost gauge is just a seperate issue?
Old Jun 23, 2002 | 04:46 AM
where does your boost gauge read from,the intake or somewhere else,im assuming that it is not on the intake or you would be reading vaccum,i agree with art,sounds like some piping or a clamp has come loose,if not,then your wastegate is stuck open or your exhaust manifold has come loose.
Old Jun 23, 2002 | 03:00 PM
Etylorcen's Avatar
Yup it was a pipe. This board never ceases to amaze me. Thanks guys. But my gauge still isnt reading boost. Im thinking its just a clogged line. Imma get some new line and rerun it and see if that works.
Old Jun 23, 2002 | 03:28 PM
Hybrid's Avatar
Do you an external wastgegate or internal with accuator? If you have an accuator check the arm connecting to the internal wastegate. If it comes off you'll build next to no boost.
Good luck, and get your self a vacume gauge.
Old Jun 23, 2002 | 06:59 PM
Etylorcen's Avatar
Default Re: Boost not kicking in...vacuum leak? (Hybrid)
Its a tial external wg. Ok i fixed the intercooler pipes but still no boost...not sure whats wrong now. I hear the turbo spooling and it blows off just slightly but no boost.
[Modified by Etylorcen, 4:00 AM 6/24/2002]
Old Jun 24, 2002 | 11:11 AM
Etylorcen's Avatar
ttt
2 point 0
Dec 31, 2004 03:09 PM
turbonitrousgsr
Oct 6, 2003 06:54 AM
incognitoracerr
Jul 28, 2003 05:55 PM
b18tdelsol
May 18, 2002 11:46 AM
