about to swap
Old Oct 31, 2007 | 09:20 AM
HONDRETTI's Avatar
Default about to swap
today i am going to jdm exchange in philadelphia to start up and observe a jdm b16 front clip from an xsi, i am wondering what precautions i should have and/or what i should be looking for to ensure its okay to accept the motor, thanks
Old Oct 31, 2007 | 09:40 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: about to swap (HONDRETTI)
um.. compression test?
If it doesn't idle horrible, or do anything that sounds like a rod is coming through the block,
I think it would be pretty decent then.
Old Oct 31, 2007 | 10:06 AM
dizzzane's Avatar
Default Re: about to swap (CleanLikeJdm)
Well most basically take the oil cap off and see what color the head is. Dark, bronze gold, still shiny aluminum? That will tell you atleast what kind of shape the engine is in if you can hear it running fine. Also listen for fluttering valves, may need an adjustment.
Old Oct 31, 2007 | 11:46 AM
HONDRETTI's Avatar
Default Re: about to swap (dizzzane)
the company says they stand by compression tests, as they test each motor before its available... the motor has 40K on it so it should be okay ? im well aware that this is basically brand new for a honda motor
thanks again
Old Oct 31, 2007 | 12:02 PM
Rikter's Avatar
LOL they all say there is only 40K on the engine. Be the hardest 40K of it's life!
-Rik
Old Oct 31, 2007 | 12:09 PM
HONDRETTI's Avatar
Default Re: (Rikter)
motor looks beautiful swap should be completed by next weds.
Modified by HONDRETTI at 4:18 PM 10/31/2007
1990JDMCRX
17
May 21, 2009 04:17 AM
sirguy01
Jul 6, 2006 09:03 PM
atmosphere
12
Apr 8, 2006 02:02 PM
handa
Aug 31, 2004 04:23 PM
IgniteTeg
Oct 30, 2002 12:34 PM
