Bought EG project car, have problem
Old Oct 15, 2007 | 02:40 PM
huge230's Avatar
Default Bought EG project car, have problem
So I bought an EG project car and was taking everything apart.
Took the rear trailing arms of to find that the previous owner welded the adjustable toe fastener to the car on 1 side. So needless to say i am not happy.
What do I do here?
Is this ok if i used adjustable toe arms given its welded securely?
This is unreal and never thought id have a problem like this
Old Oct 15, 2007 | 04:20 PM
hatchling37's Avatar
Default Re: Bought EG project car, have problem (huge230)
He welded the bolts? What a dumbass... I'm assuming your talking about the bolts that hold the adjuster in place. You shouldn't have problems with durability, I'd be more concerned with getting enough adjustment out of the part.
Old Oct 15, 2007 | 04:29 PM
huge230's Avatar
Default Re: Bought EG project car, have problem (hatchling37)
he welded the adjuster plate to the car not the bolt. I dont think the adjustment will be a problem since it seams it was welded while aligned properly lol
Think there would be any other problems just getting adjustable arms?
Old Oct 22, 2007 | 04:05 PM
huge230's Avatar
would it be worth it to try and cut it out and weld in a new section from another car? or just get toe adjusters?
Old Oct 22, 2007 | 06:54 PM
so lazy's Avatar
pictures!
Old Oct 22, 2007 | 09:14 PM
Gunns's Avatar
Do it right! Do it once!
You are just starting this project? Lets not start on the wrong foot. Cut out the subframe in that area and weld in a new one from a donor car.
Modified by Gunns at 2:20 AM 10/23/2007
Old Oct 22, 2007 | 09:29 PM
J-runEG6's Avatar
Default Re: Bought EG project car, have problem (Gunns)
Good luck with your Build. Post pics of your progress
Old Oct 23, 2007 | 05:06 AM
huge230's Avatar
thats what i was thinking, Ill just have to make sure I cut it out pretty exact.
That piece of the subframe should be the same in a DA?
Ill try and get pics when I get time to tackle this
Wilka
13
Jun 14, 2018 11:52 AM
ImportHatch
Suspension & Brakes
16
Nov 7, 2009 12:21 PM
Weel
May 5, 2009 02:34 PM
Miracle
Sep 8, 2007 11:14 AM
Stevegunit16
10
Mar 17, 2007 08:38 PM
