What problems happen for 99' Civic Si at 146k?
Old Oct 7, 2007 | 02:55 PM
kappa's Avatar
Default What problems happen for 99' Civic Si at 146k?
So I'm considering a 99' Si for $6800 but it has 146k miles on the motor. I wanted to find out what problems could potentially occur. Will this motor need a rebuild or adjustments anytime soon?
The owner is female and the car is stock besides an AEM air-intake. Paint is very good still with a couple minor scratches and dings. The car has had the following done: new battery, recent tune up: timing belt, serpentine belt, and water pump, rebuilt transmission and new clutch.
Any tips or info would be greatly appreciated. Thanks guys!
Old Oct 7, 2007 | 02:59 PM
cimo463's Avatar
Default Re: What problems happen for 99' Civic Si at 146k? (kappa)
wow that sounds like alot for the amount of miles that car has....I wouldnt do it. But thats just me
Old Oct 7, 2007 | 03:01 PM
kappa's Avatar
Default Re: What problems happen for 99' Civic Si at 146k? (cimo463)
I KBB the car and it said for "Good" condition $6800. I assumed that's where she got her price. I offered her $6500 ... still too much? Motor felt strong but would need to take it to my mechanic to get a compression test and a better idea of its condition ...
Old Oct 7, 2007 | 03:09 PM
4gencivicef9's Avatar
well if she did tune up you our good, but tune ups consist of pcv valve, spark plugs, wires, cap and rotor, fuel filter, trans service, oil and filter, tb service, coolant flush,
just go over the stuff listed, put some fuel injector cleaner, check coolant hoses, check ball joints, tie rods, shocks, bushings, ALSO check brakes and rotors...
main thing is with these cars, people beat on them or steal them so keep a alarm....and make sure no oil leaks and check tranny for no grinds, and you should be fine....
just double check timing belt if it looks new cause people lie about that stuff...
Compression test and leakdown test!!!
Old Oct 7, 2007 | 03:11 PM
if the car is in good condition and drives good it is worth it...
Old Oct 7, 2007 | 03:12 PM
kappa's Avatar
Default Re: What problems happen for 99' Civic Si at 146k? (4gencivicef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 &raquo;</TD></TR><TR><TD CLASS="quote">well if she did tune up you our good, but tune ups consist of pcv valve, spark plugs, wires, cap and rotor, fuel filter, trans service, oil and filter, tb service, coolant flush,
Compression test and leakdown test!!!</TD></TR></TABLE>
Thank you! She does have all the maintenance records and the number of her mechanic if I wanted to go over the details of the tranny rebuild and other jobs completed.
tony323
10
Apr 20, 2015 03:42 AM
redm3turbo
Jun 11, 2011 10:27 AM
ba_reefer
Mar 12, 2009 04:45 AM
teggy73
Oct 11, 2008 12:45 PM
Av06
34
Jul 12, 2007 11:56 AM
