B18B Swap Info
Hi H-T Members !
Planning swapping B18B in my EK (Civic 2000).
For the moment, I only have the engine (Base + Head + Intake + Throttle Body).
I'm making a list of what I need to complete the swap.
Can you help me to make sure I don't forget anything.
Items in italics and bold are items I currently have !
Thanks
- Engine (Base + Head + Intake + Throttle Body)
- Tranny
- Starter from Teg 94-01
- Alternator from Teg 94-01
- Headers 4-2-1
- Clutch
- Pressure Plate
- Flywheel
- Midshaft and Axles from Civic Si 99-00
- Motor mount (don't know wich one... someone as the part #)
- Ecu
- OBD2 to OBD1 conversion harness
- Distributor from B18B
- (NOT SURE) ShiftLinkage Civic Si 99-00???? (Does my shiftlinkage from my Dx is ok ?)
Does those infos are correct ? Missing any parts ?
Thanks
Thanks
- Tranny
- Headers 4-2-1
- Clutch
- Pressure Plate
- Flywheel
- Ecu
Thanks
Drivers mount bracket from SI (bolts to block)
Rear tranny bracket from SI
Shift linkage from SI
Use stock wiring harness
You might have to rewire some things depending on what year distributor/alternator/injectors you have
You can find all the info here on the site by search or FAQ.
trus01d1er
Nov 5, 2005 11:50 PM
