What temperature does everyone measure their turbo oil pressure?
Old Aug 24, 2007 | 09:02 PM
greasemonkee's Avatar
Default What temperature does everyone measure their turbo oil pressure?
Naturally the oil pressure will be higher with colder oil, but with the numbers I've seen on here for the Garrett conventional sleeve bearings, no one ever seems to specify what their oil temp is.
My setup is producing 50 psi max to the turbo at 150 degrees, but at 210 degrees it drops down to 30-35 psi. I could raise the pressure, but would it not be too high when oil is cold?
Please advise.
Old Aug 25, 2007 | 03:46 PM
Default Re: What temperature does everyone measure their turbo oil pressure? (greasemonkee)
Ok, drilled the restrictor out to .125". The line I'm using is a -4. Now the oil pressure maxes out at 65 on the turbo with oil temp around 150*. Anyone think this is too high?
hotshot100
Apr 14, 2010 05:10 PM
b18c198
Jun 8, 2005 04:58 AM
DLB1994
Nov 8, 2003 10:11 PM
BorderM3
Mar 26, 2003 11:22 AM
Speed PHreak
Apr 26, 2002 10:46 AM
