New clutch problem
Old Aug 16, 2007 | 12:57 PM
drock4688's Avatar
Default New clutch problem
any help i would appreciate, i have a 91 crx si (d16) i just put in a new stock clutch and drove fine for a day then now wont disengage at all and if you start it in gear it lurches bad.
also on top of that i was trying to see if the cable was broken and i heard a snapping noise when i pushed in the clutch, i think its the spring on the clutch pedal itself... if anyone thinks they knoa anything that could be wrong please let me know.
Old Aug 16, 2007 | 01:03 PM
drock4688's Avatar
the pedal is flopping around not attached to anything
Old Aug 16, 2007 | 01:09 PM
garageEF's Avatar
Default Re: (drock4688)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drock4688 &raquo;</TD></TR><TR><TD CLASS="quote">the pedal is flopping around not attached to anything</TD></TR></TABLE>
well it obviously came undone from the pedal....
drock4688's Avatar
Default Re: New clutch problem (drock4688)
anyone have a pic of a normal clutch pedal?
Old Aug 16, 2007 | 01:11 PM
drock4688's Avatar
Default Re: (garageEF)
is there a spring that keeps the pedal tight?
Old Aug 16, 2007 | 01:35 PM
drock4688's Avatar
anything helpful come to mind at all?
Old Aug 16, 2007 | 01:38 PM
drock4688's Avatar
up
Old Aug 16, 2007 | 01:40 PM
coot_er's Avatar
its a common problem. just do a search.
Old Aug 16, 2007 | 01:53 PM
drock4688's Avatar
Default Re: New clutch problem (coot_er)
already searched, if its so common why cant you just answer the question? anything useful to fix my car anyone? Anything othsr than telling me to keep searching would be very helpful thank you
Old Aug 16, 2007 | 03:54 PM
coot_er's Avatar
you must not have tried to hard
try "broken pedal"
https://honda-tech.com/zerothread?id=1562975
https://honda-tech.com/zerothread?id=1904353
https://honda-tech.com/zerothread?id=1531064
https://honda-tech.com/zerothread?id=1198539
YAH YAH
Jun 11, 2007 09:59 AM
H22Apexi
Jun 5, 2003 01:04 PM
civic_sir94
Dec 1, 2002 10:42 AM
navin
Apr 9, 2002 06:38 PM
Chip398193
Aug 31, 2001 03:54 AM
