CLUTCH PROBLEM
Old Jun 7, 2007 | 11:31 AM
YAH YAH's Avatar
Default CLUTCH PROBLEM
my clutch is starting to squeak i checked out the pedal and its greased up, what should i do for it to go away, it bugs the **** out of me. sorry i didnt search too lazy. please help
Old Jun 7, 2007 | 03:37 PM
posHonda's Avatar
sounds like a master cylinder to me
Old Jun 9, 2007 | 12:26 AM
YAH YAH's Avatar
Default Re: (iVteC_PoWeR)
and how do i fix that?
Old Jun 9, 2007 | 12:36 PM
deegz's Avatar
Default Re: (chiboi800)
im to lazy to do a search.
COME ON, this is exactly why honda-tech has no more tech.
Old Jun 9, 2007 | 04:43 PM
[ iLL ] iNt3GrA's Avatar
Default Re: (deegz)
Does it make a noise when u press the clutch down? or does it make it when you do not press the pedal?
...if it makes it when you do not hit the clutch but then it goes away when u press the pedal it is the throw out bearing on the clutch
Old Jun 10, 2007 | 10:46 AM
YAH YAH's Avatar
Default Re: ([ iLL ] iNt3GrA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ iLL &raquo;</TD></TR><TR><TD CLASS="quote"> iNt3GrA]Does it make a noise when u press the clutch down? or does it make it when you do not press the pedal?
...if it makes it when you do not hit the clutch but then it goes away when u press the pedal it is the throw out bearing on the clutch</TD></TR></TABLE>
no it makes a noise when i push it down and releasing it.
Old Jun 10, 2007 | 11:08 AM
so it makes the noise all the time? or just when ur on the clutch,
Old Jun 11, 2007 | 02:05 AM
YAH YAH's Avatar
only when im on the clutch<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ iLL &raquo;</TD></TR><TR><TD CLASS="quote"> iNt3GrA]so it makes the noise all the time? or just when ur on the clutch, </TD></TR></TABLE>
Old Jun 11, 2007 | 05:10 AM
HONDA RR's Avatar
^^^^ Your clutch release bearing is probably going out.
Old Jun 11, 2007 | 09:59 AM
Default Re: (HONDA RR)
have some one press the clutch and see where the noise is coming from.... if it is inside the bell housing then u know your gonna have to drop the trans to fix it
96lude_srv
Jun 12, 2006 12:05 PM
jbsmith
Aug 29, 2005 12:21 AM
jdmcivicferio
Jul 9, 2004 02:15 PM
fiebru1119
Aug 20, 2002 10:07 AM
eh-D
May 12, 2002 10:00 AM
