Squeaky Clutch????
Old Aug 30, 2001 | 10:26 AM
Chip398193's Avatar
New User
Default Squeaky Clutch????
Recently in my LS, the clutch started squeaking when its almost all the way down. It does it quite often now, and its somewhat annoying. I also can feel a little roguhness at that point. Im wondering, is there sometihng i should oil or fix? can someone help me out?
Thanks
Old Aug 30, 2001 | 12:00 PM
GSdriver's Avatar
Default Re: Squeaky Clutch???? (Chip398193)
I had a problem similar to your - it was the pin that connects the clutch pedal arm to the pushrod for the slave cylinder. I sprayed some lithium grease on it and the noise went away...
Old Aug 30, 2001 | 02:48 PM
GruvyTune's Avatar
New User
Default Re: Squeaky Clutch???? (GSdriver)
same here. lube spray on the fork cured it. ******' dealer's "master tech" said i needed a new clutch!
Old Aug 30, 2001 | 02:52 PM
GSRwBOOST's Avatar
Default Re: Squeaky Clutch???? (GruvyTune)
mine squeeks when the clutch is alll the way out.. mostly in neutral... is it the same cause?
Old Aug 30, 2001 | 04:14 PM
90integraGS's Avatar
New User
Default Re: Squeaky Clutch???? (GSRwBOOST)
Chip- I don't mean to sound ignorant, but do you have a hydraulic or cable clutch? I've got a cable clutch that squeaks and I've been speculatin' during quiet moments on how to fix it.
Old Aug 31, 2001 | 03:54 AM
New User
Default Re: Squeaky Clutch???? (cotton_lix)
Wait a minute-what was the original problem? Your clutch pedal squeaks as you step on it? Or when you have the pedal all the way down you can hear the clutch disk squeaking?
Dre_559
May 28, 2009 08:23 PM
renes
Nov 21, 2005 11:25 AM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
tnsxsear1
May 18, 2004 09:56 AM
