What exactly does the map sensor do?
Old Jun 12, 2002 | 12:03 PM
thashadow's Avatar
Default What exactly does the map sensor do?
i was having problems starting my car yeasterday, and i was just messing around with stuff..So i took the map sensor out, and it started, and ran fine.
Today i'm having the same problems starting without it in, and i pop it back in, and it starts and runs just fine. My engine seems kinda moody.
what does the map sensor do, and is it necessary?
Old Jun 12, 2002 | 12:10 PM
thashadow's Avatar
Default Re: What exactly does the map sensor do? (allmotorgurl)
what do you mean codes?
Old Jun 12, 2002 | 12:13 PM
that SCION girl's Avatar
Default Re: What exactly does the map sensor do? (thashadow)
what kind of car do u have first of all ....the codes are check engine codes that appear ...on your ECU ...or dash ...
Old Jun 12, 2002 | 12:14 PM
thashadow's Avatar
92 civic si eh2
ok thanx
Old Jun 12, 2002 | 12:23 PM
u have a local speed shop ??...have them check the codes ...either that or ..im me if you need more detailed help
[Modified by allmotorgurl, 3:49 PM 6/12/2002]
Old Jun 12, 2002 | 02:01 PM
Katman's Avatar
codes/mil codes/check engine light. do you have one lit up on your idiot gauge? if so, if you'd like to find out what code that check engine light is throwing, you need to go look under the passenger side of your dash for a green rubber cube.
that's here:
In that green cube, you'll find 2 plugs inside of it. Pull the smaller plug out and jump it while the your car is on and your check engine light is on also....
if you don't know what I'm talking about go here and read TIP 2:
http://ff-squad.com/autoP30.htm
once you jump that smaller plug, watch the check engine light in your gauge cluster. It should start blinking. Take note of how many times it blinks, but remember...
long blinks=incriments of 10
short blinks=incriminents of 1
So, lets say you have one long blink followed by 7 fast blinks...that's code 17.
and here's the factory Honda code breakdown:
http://tiiite.b16a.com/ecu/mil-codes_1.jpg
hth.....lates.
[Modified by Katman, 3:02 PM 6/12/2002]
Old Jun 12, 2002 | 02:15 PM
Mikey3000's Avatar
MAP= mass air pressure
MAP = manifold absolute pressure <<<<<< most important sensor on the car
[Modified by Boss Hogg, 6:16 PM 6/12/2002]
Old Jun 12, 2002 | 02:21 PM
Default Re: What exactly does the map sensor do? (Boss Hogg)
THANKS...lol...remind me not to post in tech anymore ...when it is wiring or ecu related ....DOH !!!
[Modified by allmotorgurl, 3:23 PM 6/12/2002]
Old Jun 12, 2002 | 02:25 PM
sgT's Avatar
sgT
Personally, i think the cam/crank angle sensors are more important
Old Jun 12, 2002 | 02:32 PM
Chiovnidca's Avatar
It senses how much air is going into the engine.
The MAP sensor tells the Ecu what the presure of the air in the intake manifold is. The MAP sensor has no idea how much air is flowing.
Old Jun 12, 2002 | 05:00 PM
thashadow's Avatar
Default Re: What exactly does the map sensor do? (Chiovnidca)
thanks a lot people, this has been mad helpful.
they really didn't tell me much in teh civic board. i get a blow by blow instruction manuel in here...
1993eghatch
Jun 24, 2010 03:25 PM
liftdhatch95
Dec 24, 2007 12:17 PM
Seth94GSR
Jun 14, 2006 09:59 PM
MIZIKETSK
Jun 15, 2004 06:36 AM
BeanRacer
Nov 24, 2001 11:15 AM
