Codes
Old Jun 8, 2006 | 02:13 PM
Seth94GSR's Avatar
Default Codes
Looking for a list of codes that the check engine light throws when you check them...
Old Jun 8, 2006 | 02:15 PM
jdm_bones's Avatar
Default Re: Codes (Seth94GSR)
do you know what code you are throwing already?
Old Jun 8, 2006 | 02:16 PM
Seth94GSR's Avatar
Default Re: Codes (jdm_bones)
I'm throwing 3 and 10, But I believe that is the map and iac. Correct me if I'm wrong. What ever it is, its causing me to auto-rev. Because its not any of my vaccums..
Old Jun 8, 2006 | 02:18 PM
jdm_bones's Avatar
Here is the list of codes for your Teg check it:: https://honda-tech.com/zerothread?id=978933
Old Jun 8, 2006 | 02:21 PM
Seth94GSR's Avatar
Well I know its not the map sensor, I changed that out already with a new one...and I highly doubt the IAT sensor is going to cause my engine to auto-rev..This is costly man...Thanks for the help though. I appreciate it.!
jdm_bones's Avatar
Something is up with your TB, did you remove any of the sensors, like the MAP or IAT. Try cleaning them first, plug them in right. Make sure your car is off while you do this, Then reset your ecu, by unpluging your negitive battery cable. then check it again.
Old Jun 8, 2006 | 02:25 PM
jdm_bones's Avatar
When you replaced the MAP, I think that you put in wrong, check with a voltimeter, I think it's a postion problem of your Map.
Seth94GSR's Avatar
Alright. I'll be back in a few..I'll let you know what happens. Thanks again.
jdm_bones's Avatar
Is it giving you a loopy rev?
Old Jun 8, 2006 | 02:27 PM
Seth94GSR's Avatar
Oh and there is only one position that the map sensor will fit on the gsr TB...Or maybe the TB itself could just be dirty..I don't know though, but I'm going to check it out right quick...and spray some brake cleaner on it..or in a cup and let it set for a few.
Old Jun 8, 2006 | 02:28 PM
Seth94GSR's Avatar
It revs from 800 - 2500, repeatively..
Old Jun 8, 2006 | 02:30 PM
jdm_bones's Avatar
Do me a favor and check your coolent, this also happenes when you are low on coolent, make sure that you fill it, and bleed out all the air from radiator.
Old Jun 8, 2006 | 02:32 PM
jdm_bones's Avatar
Have you removed the TB it self?
Old Jun 8, 2006 | 02:33 PM
Seth94GSR's Avatar
Did that already, and the coolent is full to the top..no airbubbles..
jdm_bones's Avatar
I am thinking a bad TB gasket or if removed it you didn't use the correct bolting on pattern, and now it's leaking from somewhere!
Old Jun 8, 2006 | 02:34 PM
Seth94GSR's Avatar
Haven't removed it yet. Checking all of the minor things that might be causing the problem...then to the major issues..
Old Jun 8, 2006 | 02:35 PM
jdm_bones's Avatar
When you give it abit of gas does it go away? Is it hard to start? Do you have to give it gas to start it?
Old Jun 8, 2006 | 02:36 PM
Seth94GSR's Avatar
Ok, I'll check for that when I take my TB off...Oh and some other guy said it might be from a beant valve...Which isn't really possible is it?
Old Jun 8, 2006 | 02:37 PM
Seth94GSR's Avatar
It starts fine, give it gas it stops...Its just when I'm at idle or when the clutch is fully engaged.
Old Jun 8, 2006 | 02:39 PM
jdm_bones's Avatar
Could be, but you would hear a weried sound coming from your head when you rev, and even at idel. And haven't said anything about any noise!
Old Jun 8, 2006 | 02:41 PM
Seth94GSR's Avatar
Nah, no noise, Just the normal infinite valve tap...but other than the auto-reving its fine. I would just really like to fix this today. Or at least sometime tomorrow.
Old Jun 8, 2006 | 02:42 PM
jdm_bones's Avatar
Do you have a stock fuel pressure regulator?
Old Jun 8, 2006 | 02:43 PM
jdm_bones's Avatar
Check the vaccum line on your FPR, please!
Old Jun 8, 2006 | 02:51 PM
Seth94GSR's Avatar
By the fuel rail at the top?
Old Jun 8, 2006 | 02:55 PM
jdm_bones's Avatar
yes, are you running an aftermaket FPR? If so what fuel pressure are you running it at? If not check for fuel leaks at the fuel rail, and injectors, also at the fuel filter...
