CEL from HELL
Old Aug 9, 2007 | 09:17 AM
highflyin250x's Avatar
Default CEL from HELL
Ok... i must be overlooking something easy.
93 civic EX, 95 B16 SiR motor just swapped in. Left the ex harness. Went in smooth and it runs fine. Check Engine Light is throwing a code for vehicle speed sensor. The speedometer works (signal is getting to cluster) VTEC engages (signal is getting to the ECU) i also put the ECU in another car and it didn't throw a code. I replaced the VSS and it made no difference.
I have been messing with this for a while now and i can't figure out why it would be throwing a code. I need to get this car done so i can drive it out to school.
Any one have any ideas... and help would be great
Old Aug 9, 2007 | 09:22 AM
Dool_Ohver_Hed_Cam's Avatar
Default Re: CEL from HELL (highflyin250x)
sounds like it could be a wiring issue. only thing i can think of is trying your vss on another car to see if it's faulty.
Old Aug 9, 2007 | 09:36 AM
THC07's Avatar
may be that the plug is not making a connection 100% of the time, jus that split secound to get a cell. when you reset the code will it come back fast, or does it vary? i had a nightmare from hell with a plug problem, that is why i ask.
Old Aug 9, 2007 | 09:50 AM
Default Re: CEL from HELL (THC07)
no thats the weird part to me too, i was thinking that if it was wiring it would be intermittent, but it comes on immediately and stays on.
Old Aug 9, 2007 | 10:14 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check that the No. 15 (7.5A) fuse is not blown or missing. A blown or missing No. 15 fuse can trigger the VSS trouble code, especially when the wheels are turned.
Otherwise, it is most likely a wiring issue on the engine harnesses.
Old Aug 9, 2007 | 10:15 AM
speedooo's Avatar
i had an issue where if i hit a bump hard the speedo would go to 220kmh and shoot back to normal, after changing the vss twice it turns out the plug on the harness side went bad
Old Aug 9, 2007 | 10:35 AM
PinoyxEJ6's Avatar
Default Re: CEL from HELL (speedooo)
ROFL on the Topic Title lol...
suprant0010
Apr 19, 2014 02:41 AM
nicefighter80
Jan 15, 2011 08:53 AM
Kris's turbo
Apr 10, 2009 07:24 AM
Japankid
Apr 7, 2009 01:45 PM
Heylookits shawn
13
Oct 26, 2006 07:50 AM
