HELP: SWAPPING D16Y8 (OBD2A) MOTOR IN 95 HATCH (OBD1)
Old Aug 6, 2007 | 06:07 AM
gotboosthatch's Avatar
Default HELP: SWAPPING D16Y8 (OBD2A) MOTOR IN 95 HATCH (OBD1)
hey guys i serched and cant find anything... what all do I need to swap a d16y8 motor which is obd2a from a 1996 civic into my 1995 hatch which is obd1..
if you guys could help me out it would be greatly appreciated.. thanks
Old Aug 6, 2007 | 09:54 AM
help?
Old Aug 6, 2007 | 10:02 AM
mustang5.slow's Avatar
* B A N N E D *
Default Re: (gotboosthatch)
you will keep the same harness. and the ObD 1 fuel injectors, alt and starter, the distributor you Will use the OBD 2 and just ree-pin it to the OBD 1 plugs. and that is basically it the rest is just plug and play.
any other Q.'s I'll be glad to help.
Old Aug 6, 2007 | 10:12 AM
924doorEG's Avatar
obd2 distributor, obd2 to and obd1 jumper harness p28 ecu, and the obd1 engine harness
Old Aug 6, 2007 | 11:11 AM
speedooo's Avatar
Default Re: (924doorEG)
if you have an si, you need to use a cx/dx/lx distributor on the y8, reuse the alternator, starter and harness off of your old motor and everything else will plug up using a p28. depending on the model you might have to run extra wires for vtec and a different o2 sensor since the cx uses a 1 wire and the vx uses 5 wire. try to find an ex/si harness and you wont have to do wiring
Old Aug 6, 2007 | 11:28 AM
I have a 95 vx.. So I can't use the p2p ecu made for the y8 motor?
Old Aug 6, 2007 | 11:31 AM
I have an ex harness from a 93 ex which had a d16z6 in it
Old Aug 6, 2007 | 11:35 AM
speedooo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 vx.. So I can't use the p2p ecu made for the y8 motor?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch &raquo;</TD></TR><TR><TD CLASS="quote">I have an ex harness from a 93 ex which had a d16z6 in it</TD></TR></TABLE>
you can, but it would be alot easier to just use a p28 since your car is obd1. just use the z6 harness and it will be plug and play
Old Aug 7, 2007 | 11:22 AM
so if I use the z6 harness I dont have to switch injectors, Alt, starter,dizzy? What would I need to use the p2p ecu?
Old Aug 7, 2007 | 01:28 PM
anyone?
Old Aug 8, 2007 | 10:44 PM
anyone?
BoostedRedline
Apr 14, 2007 01:22 PM
6doorsentra
14
Oct 8, 2006 11:36 PM
ebp_dc2
12
Mar 13, 2006 04:49 PM
_HANS
Jun 29, 2004 03:29 PM
ErikDaGenErik
Aug 30, 2003 01:09 AM
