Looking for a MAP Sensor block off plate with no holes.
Old Aug 1, 2007 | 10:56 AM
MidwestAutoWorks's Avatar
Default Looking for a MAP Sensor block off plate with no holes.
Looking for a MAP sensor block off plate with no holes in it.
I will be using the AEM 3.5 BAR in a different place.
Old Aug 1, 2007 | 10:57 AM
SovXietday's Avatar
Default Re: Looking for a MAP Sensor block off plate with no holes. (MidwestAutoWorks)
Search missing link.
Old Aug 1, 2007 | 11:00 AM
locash's Avatar
I'd say to use the adapter from TunerToys, and you can either put in an 1/8" npt plug, or use the fitting for another item that needs vacuum, ie: BOV..
http://tunertoys.zoovy.com/c=T...APTER
Old Aug 1, 2007 | 11:01 AM
Default Re: Looking for a MAP Sensor block off plate with no holes. (locash)
Like I said i do not want a hole in it, it can be a piece of .5 aluminum as long as it blocks that hole
Old Aug 1, 2007 | 11:03 AM
NEVERMIND
I just realized that the new throttle body's map hole is threaded, I can just throw a plug in it.
Old Aug 1, 2007 | 11:06 AM
Kyle R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">NEVERMIND
I just realized that the new throttle body's map hole is threaded, I can just throw a plug in it.</TD></TR></TABLE>
Old Aug 3, 2007 | 08:31 AM
JSPECSIR's Avatar
Default Re: Looking for a MAP Sensor block off plate with no holes. (herecomesboost)
you couldve always just left your stock map bolted down and unplugged.
Old Aug 3, 2007 | 08:35 AM
Default Re: Looking for a MAP Sensor block off plate with no holes. (JSPECSIR)
Could have but Im going for the clean look.
My brother in law who is an engineer has decided to machine a few of these.
Old Aug 3, 2007 | 06:39 PM
TunerToys's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">I'd say to use the adapter from TunerToys, and you can either put in an 1/8" npt plug, or use the fitting for another item that needs vacuum, ie: BOV..
Thanks Joe,
Here is a pic...
The block off plate is an interesting idea. What are you going to use as an alternate location for connecting the MAP?
Craig
Old Aug 3, 2007 | 10:17 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">Could have but Im going for the clean look.
My brother in law who is an engineer has decided to machine a few of these.</TD></TR></TABLE>
You could have also stuck a motorola 3bar or 4bar into an OEM housing and made some extra money fooling the locals at the track.
Old Aug 4, 2007 | 05:49 AM
Default Re: Looking for a MAP Sensor block off plate with no holes. (HiProfile)
I have the AEM 3.5 bar map sensor
Old Aug 4, 2007 | 09:13 AM
Turbogixxer's Avatar
http://www.roskoracing.com/MAP_Sensor_Block.html
Old Aug 5, 2007 | 07:10 PM
GetawayInMoscow's Avatar
Default Re: Looking for a MAP Sensor block off plate with no holes. (Turbogixxer)
A stock map or a tunertoys adapter isn't clean but a block off plate is?
OCD
hybrid1990crx
Nov 1, 2010 07:03 AM
allnaturalb16
Oct 19, 2007 10:14 PM
da9blk1
Oct 16, 2007 02:41 AM
pissedoffsol
Dec 5, 2003 04:58 PM
01ITR#700
Apr 24, 2003 10:28 AM
