Swap done, starts and drives but bogs out at 3k rpms
Old Jul 31, 2007 | 02:58 PM
ekhatch978's Avatar
Default Swap done, starts and drives but bogs out at 3k rpms
ive got a 95 b18c1 in a 97 hatch. finally got it going and got a check engine light. the problem is i cant get the codes. the scan tool doesnt read cause i converted to obd1 and whehn i try to jump the codes the light doesnt blink
engine starts and idles fine, all the gears work and it accelerates fine. when i drive it it bogs out a little after 3,000 rpms. its like it hits a rev limit. at 1st i thought it was something to do with the vtec not kicking in. i havent changed the solenoid yet but ive checked all the wires and everything seems fine.
is this what usually happens just from vtec not kicking in? or is something else causing the check engine light and causing the car to stay in "safe mode"? i know its a broad question but is there any specific code that would cause this to happen? or is it just cause somethings wrong with the vtec?
Old Jul 31, 2007 | 03:03 PM
be18see1's Avatar
Default Re: Swap done, starts and drives but bogs out at 3k rpms (ekhatch978)
no its not vtec. it just wouldnt kick. besides that, i cant offer any more input. good luck.
Old Jul 31, 2007 | 03:06 PM
ekhatch978's Avatar
thanks man that eliminates one headache.
i also have a skun2 intake mani not sure if that might be throwing a code. i might have to just spend the money and take it to a shop cause im not sure anyone can know exactly what codes or a specific problem that would make it do this
Old Jul 31, 2007 | 05:29 PM
ekb16's Avatar
wut ecu r u running
Old Jul 31, 2007 | 06:36 PM
Hybrid96EK's Avatar
Default Re: (ekhatch978)
Its not bogging, its hitting the limiter because its in limp home mode. Solid CEL + no blinking when bridged = bad ECU/chip.
Old Jul 31, 2007 | 06:38 PM
Jason-'s Avatar
Check tps?
-Jason
Old Aug 1, 2007 | 05:32 PM
ekhatch978's Avatar
i bought an ecu off ebay.the guy sent me a p06 converted to manual with vtec added. the chips just a basemap gsr with knock sensor and secondary o2 disabled. he had alot of good feedback so i dont know. i have to send it back to him for a new one.
Old Aug 1, 2007 | 05:44 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatch978 &raquo;</TD></TR><TR><TD CLASS="quote">i bought an ecu off ebay.the guy sent me a p06 converted to manual with vtec added. the chips just a basemap gsr with knock sensor and secondary o2 disabled. he had alot of good feedback so i dont know. i have to send it back to him for a new one.</TD></TR></TABLE>
Well, clearly its not correct. Also, you can't disable the secondary O2 with OBD1 since OBD1 doesn't support/look for a secondary O2. The knock sensor wouldn't work with a P06 either since it doesn't have a knock board. Sounds like a problem with the conversion or the chip itself like I said earlier.
chadleehonda
Jun 30, 2010 07:35 PM
punkriderf3
10
Jun 7, 2007 07:06 PM
killakoupe
May 8, 2007 07:43 PM
TheIceMan
Dec 10, 2005 11:33 AM
05r1
16
May 20, 2005 08:21 AM
